Has anyone succeeded in configuring two remote Mikrotik routers connected via the internet with PPTP, so that the Bonjour protocol works between the two LAN.
EOIP seems an option but I fear that the traffic generated will be very heavy (unnecessary DHCP, broadcasts, …), I just need the Bonjour protocol to function.
hi
you can do simply
you must run pptp in your router’s
set the same ip in two router’s
for example
MT(1),ip address=192.168.1.1/30
MT(2),ip address=192.168.1.2/30
if your lan in first router have ip address range 172.16.10.0/24 and in second router have 172.16.11.0/24,you must add this route in ip route:
in MT(1): /ip route add dst-address=172.16.11.0/24 gateway=192.168.1.2
in MT(2): /ip route add dst-address=172.16.10.0/24 gateway=192.168.1.1
with this config lan 1 and lan 2 connect toghether from pptp protocol.
You partially answered your own question. Bonjour is multicast, so you’d need to use something that facilitates a bridge (like EoIP) or does multicast routing. MikroTik appears to support Multicast routing, but I’m not sure if Bonjour will support it.
I would however like to find a solution avoiding EOIP, as I suspect that configuration would generate far more traffic than requested just for the Bonjour protocol.
I would imagine a VPN connection of both networks, and a multicast configuration that would allow the Bonjour protocol to be routed.
