two routers OSPF
Hello there,
I am trying to connect 2 routers with OSPF. After everything I’ve read and followed many guides how to set up ospf I came to point where from router A (RB1100X2H) I can ping router B (RBSEXTANT), see him in neighbors list but I can access that router only via MAC telnet and router B doesn’t show in winbox. After setting up the configuration I’ve tried to connect router B directly to my computer and again with no success. I’ve reconfigured them like 10 times following different tutorials but again nothing. What should I provide to you so I can get some help?
Thank you in advance
The configs (output from /export compact) and a simple diagram of what is connected where would be a good starting point.
I assume you are referring to winbox neighbor discovery. Winbox discovers routers in the same L2 broadcast network.
Simple diagram of what I've done till now is attached to this message. CelticComms here is what you've been looking for:
ROUTER A (RBHX2):
jan/02/1970 00:02:13 by RouterOS 5.25
software id = UDVF-02V3
add name=pppoe
add name=loopback
/interface pppoe-server
add name=itm_pppoe_server service="" user=""
/interface eoip
add mac-address=02:70:D0:92:4C:AE name=eoip-viniche remote-address=
253.25.15.13 tunnel-id=113
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=itm_pool1 ranges=10.10.10.10-10.10.10.250
/ppp profile
add dns-server=10.10.10.1,8.8.8.8 local-address=10.10.10.254 name=itm_profile
rate-limit=1024000/1024000 remote-address=itm_pool1 session-timeout=12h
/routing ospf instance
set [ find default=yes ] mpls-te-area=backbone mpls-te-router-id=loopback
redistribute-connected=as-type-1 router-id=253.25.15.10
/tool user-manager customer
add backup-allowed=yes disabled=no login=admin password=""
paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no
permissions=owner signup-allowed=no time-zone=-00:00
/tool user-manager profile
add name=USER name-for-users="" override-shared-users=1 owner=admin price=650
starts-at=logon validity=4w2d
/tool user-manager profile limitation
add address-list="" download-limit=0B group-name="" ip-pool=itm_pool1 name=
simple_users rate-limit-burst-rx=8192000B rate-limit-burst-time-rx=8s
rate-limit-burst-time-tx=8s rate-limit-burst-treshold-rx=3072000B
rate-limit-burst-treshold-tx=2048000B rate-limit-burst-tx=8192000B
rate-limit-min-rx=262144B rate-limit-min-tx=262144B rate-limit-rx=
4096000B rate-limit-tx=4096000B transfer-limit=0B upload-limit=0B
uptime-limit=0s
add bridge=pppoe interface=ether2
add bridge=pppoe interface=eoip-viniche
add bridge=pppoe interface=ether10
/interface pppoe-server server
add default-profile=itm_profile disabled=no interface=pppoe
keepalive-timeout=disabled one-session-per-host=yes service-name=
itm_pppoe_config
add address=10.10.10.1/24 interface=pppoe
add address=253.25.15.10/32 interface=loopback network=253.25.15.10
add address=253.25.0.5/30 interface=ether5
/ip dhcp-client
add default-route-distance=0 disabled=no interface=ether1
set allow-remote-requests=yes cache-size=10000KiB
add action=masquerade chain=srcnat src-address=10.10.10.0/24
/ip neighbor discovery
set eoip-viniche disabled=yes
/ppp aaa
set use-radius=yes
/ppp secret
add name=itm password=itm123 profile=itm_profile service=pppoe
/radius
add address=127.0.0.1 secret=123456 service=ppp
/radius incoming
set accept=yes port=1700
/routing ospf network
add area=backbone network=253.25.0.4/30
/system identity
set name=MAIN_ROUTER
/system logging
add disabled=yes topics=ospf
/tool user-manager profile profile-limitation
add from-time=0s limitation=simple_users profile=USER till-time=23h59m59s
weekdays=sunday,monday,tuesday,wednesday,thursday,friday,saturday
/tool user-manager router
add coa-port=1700 customer=admin disabled=no ip-address=127.0.0.1 log=
auth-ok,auth-fail,acct-ok,acct-fail name=ITM shared-secret=123456
/tool user-manager user
add customer=admin disabled=no name=admin password=123456 shared-users=1
wireless-enc-algo=none wireless-enc-key="" wireless-psk=""
ROUTER B (RB SEXTANT):
add name=loopback
/interface wireless
set 0 disabled=no l2mtu=2290 mode=bridge
redistribute-connected=as-type-1 router-id=253.25.15.11
add address=253.25.5.6/30 interface=wlan1
add address=253.25.15.11/32 interface=loopback network=253.25.15.11
add address=253.25.0.6/30 interface=ether1
add distance=1 gateway=loopback
add area=backbone network=253.25.5.4/30
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set loopback disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
/system leds
set 0 interface=wlan1
/system routerboard settings
set cpu-frequency=600MHz
ROUTER C (RB SEXTANT):
jan/02/1970 00:09:57 by RouterOS 5.25
software id = CQW0-R9NW
add name=loopback
/interface wireless
set 0 band=5ghz-a/n disabled=no ht-ampdu-priorities=0,1,2,3,4,5,6,7
ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 radio-name=viniche-H2O ssid=
MikroTik wireless-protocol=nv2-nstreme-802.11
/interface wireless nstreme
set wlan1 enable-nstreme=yes
redistribute-connected=as-type-1 router-id=253.25.15.12
add address=253.25.5.5/30 interface=wlan1
add address=253.25.15.12/32 interface=loopback network=253.25.15.12
add address=253.25.0.9/30 interface=ether1
add area=backbone network=253.25.0.8/30
/system identity
set name=Viniche-H2O
/system lcd
/system lcd page
/system leds
ROUTER D (RB2011 UAS-2HNS-IN):
jan/02/1970 00:12:26 by RouterOS 5.25
software id = HFQG-F4AK
add name=loopback
add l2mtu=1598 name=pppoe
/interface eoip
add mac-address=02:46:2E:33:9F:54 name=eoip-viniche remote-address=253.25.15.10
tunnel-id=113
set [ find default=yes ] redistribute-connected=as-type-1 router-id=
253.25.15.13
add bridge=pppoe interface=ether6
add address=253.25.0.10/30 interface=ether1
add address=253.25.15.13/32 interface=loopback network=253.25.15.13
/system lcd
/system lcd page
set pppoe disabled=yes display-time=5s
set ether10 disabled=yes display-time=5s
set ether9 disabled=yes display-time=5s
set eoip-viniche disabled=yes display-time=5s
set ether8 disabled=yes display-time=5s
set ether7 disabled=yes display-time=5s
set ether6 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set sfp1 disabled=yes display-time=5s
Hope I am doing good till now. I am new in networking and Mikrotik.
anyone here to help?
I’ll take a look at the config, but here are the most common OSPF neighbor issues:
Duplicate router ID
OSPF Network type mismatch
MTU Mismatch
Multicast for ospf (224.0.0.5 and 224.0.0.6) not permitted
Network subnets advertised don’t match on either side of the adjacency
Mismatched hello/dead timers
Cisco has a great doc on OSPF troubleshooting that is valid for all platforms since OSPF is open standard
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094050.shtml
Check your router ID’s in
/routing ospf instanceBecause I do not see them in your config, I assume they are default, and therfore all routers will have 0.0.0.0.
Set them differently on all 4 (like you did with the loopback IP’s which you probably created for the router ID’s)
Change your IP addresses to a Class A, B or C range - I did a quick test of this on two MikroTik VMs and could not establish a neighbor adjacency - as soon as I switched to RFC 1918 space (192.168.0.0/30) the neighbors immediately came up.
The IP addresses you are using are in the Class E - Experimental range which is not supported by all network devices in the TCP/IP stack
See this article for more info:
http://packetlife.net/blog/2010/oct/14/ipv4-exhaustion-what-about-class-e-addresses/
Another interesting note on this…I attempted to put the same address into a Cisco router and it won’t even accept it on the interface:
R2(config-if)#ip address 253.25.0.5 255.255.255.252
Not a valid host address - 253.25.0.5
R2(config-if)#
