Good Day,
Is there any example of setting up second router to use userman on the first router for PPPOE authentication?
Userman works great on first router, but we would like our second router to use the first routers Radius Authentication.
How would I go about doing this?
Any info would be appreciated.
Thanks in advance
There should be the same configuration on Router2 for RADIUS client.
you may use this configuration example,
http://wiki.mikrotik.com/wiki/User_Manager/PPP_Example
Thanks for the reply,
So basically I do the same setup as for the first router on the second one…
Shared key…same as first router.
Router … Setup to point to first routers ip address
etc.
