Two SR5s in an RB112
Can you put two SR5s in a Routerboard 112?
Are there any differences in the power supply compared to a RB 532 that would make this impossible?
George
I would be interested to know the answer to this as well.
Reading the manual for the RB532 there seems to be ~10W spare for MiniPCI cards whereas its more like ~6W spare on the RB112.
Would I be correct in saying that if you run the SR5’s at 200mW they will consume less power?
Malcolm
It is not a SR5, but I’ve tested a SR2 and a CM9 in a RB112. It ran fine for one hour and then the device started to reboot over and over. I removed the CM9 and it ran ok.
The SR2/5 drain too much power to have a second card in a RB112.
I have about a dozen RB112’s with two SR2’s running with no problems. I also have several others with a SR9 and either a SR5 or SR2.. I only use the Pac Wireless POE-48i power injectors..
-Gerard
I’m using 18v (15w) power supply. This is probably why I’m having problems… :confused:
Gerard,
Do you run them at full power and are they in busy locations - am thinking duty cycle here?
Do you have much problem with heat?
Regards,
Malcolm
I only run them at default tx power..
Most of them are just simple repeaters with 2-4 clients connected to the AP side. But they stay running for weeks without random reboots or problems. Usually the only time they restart is for upgrades.
I use the Pac Wireless aluminum enclosures and they get warm but not nearly as warm as the RB532’s do with 2 SRx’s and clocked at 330mhz..
I have another 10+ RB112’s with a SR2 or SR9 and a CM9 running as CPE’s also.
-Gerard
