This has been discussed before. I’ve read everything I can find, here in the MikroTik forums and elsewhere on the Internet.
I’m still not getting it to work…
RouterBOARD 1200, firmware 2.33, RouterOS 5.5 (yes, I know, it’s old; I will update it, but this is in production and I’m quite conservative, and I see nothing in the changelog to suggest that anything from 5.6 through the current 5.21 has anything to do with this problem).
One Ethernet interface (ether5), two internal IP addresses; plus public Internet address on ether6 (and the default config on ether10 which we just ignore and don’t use); flat (layer 2 switches, unintelligent) network connected to ether5.
[socialpoint@MikroTik] > /ip addr print det
0 ;;; default configuration
address=192.168.88.1/24 network=192.168.88.0 interface=ether10 actual-interface=ether10
1 ;;; Orange fiber Internet connection (100Mb symmetric)
address=xx.yy.zz.aa/30 network=xx.yy.aa.ab interface=ether6 actual-interface=ether6
2 ;;; LAN
address=192.168.1.1/24 network=192.168.1.0 interface=ether5 actual-interface=ether5
3 ;;; LAN (also)
address=192.168.4.1/24 network=192.168.4.0 interface=ether5 actual-interface=ether5
Just the dynamic routing table entries:
(The missing numbers in the lists below are entries which exist but are disabled, e.g. some custom routes we occasionally use when we want traffic to go out one or another Internet interface; we actually have several, but our normal configuration is for only the one on ether6 to be enabled, and all the others - as they are now - to be disabled, so they have no bearing on the current problem).
Short form
[socialpoint@MikroTik] > /ip rout print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
3 A S ;;; Default Internet connection, Orange
0.0.0.0/0 xx.yy.zz.ab 1
6 ADC xx.yy.zz.aa/30 xx.yy.zz.ac ether6 0
10 ADC 192.168.1.0/24 192.168.1.1 ether5 0
11 ADC 192.168.2.0/24 192.168.2.2 ether4 0
12 ADC 192.168.3.0/24 192.168.3.2 ether7 0
13 ADC 192.168.4.0/24 192.168.4.1 ether5 0
14 ADC 192.168.88.0/24 192.168.88.1 ether10 0
Long form:
[socialpoint@MikroTik] > /ip rout print det
dst-address=0.0.0.0/0 gateway=xx.yy.zz.ab gateway-status=xx.yy.zz.ab reachable ether6 distance=1 scope=30 target-scope=10
6 ADC dst-address=xx.yy.zz.aa/30 pref-src=xx.yy.zz.ac gateway=ether6 gateway-status=ether6 reachable distance=0 scope=10
10 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.1 gateway=ether5 gateway-status=ether5 reachable distance=0 scope=10
11 ADC dst-address=192.168.2.0/24 pref-src=192.168.2.2 gateway=ether4 gateway-status=ether4 reachable distance=0 scope=10
12 ADC dst-address=192.168.3.0/24 pref-src=192.168.3.2 gateway=ether7 gateway-status=ether7 reachable distance=0 scope=10
13 ADC dst-address=192.168.4.0/24 pref-src=192.168.4.1 gateway=ether5 gateway-status=ether5 reachable distance=0 scope=10
14 ADC dst-address=192.168.88.0/24 pref-src=192.168.88.1 gateway=ether10 gateway-status=ether10 unreachable distance=0 scope=200
The problem, as others have posted, is that devices on 192.168.4.0/24 cannot reach 192.168.1.0/24.
DHCP supplies IP addresses including the default gateway being the MikroTik on the same subnet as the DHCP client.
The clients can all reach anything else on their own subnet, and anything on the Internet.
Here’s a sample pair which can’t talk:
- My workstation (Windows 7), DHCP-assigned IP address 192.168.4.21/24, default gateway 192.168.4.1 (the MikroTik, on ether5).
- A simple Wi-Fi access point, 192.168.1.193 statically configured, with default gateway 192.168.1.1 (also the MikroTik, also on ether5).
Traceroute:
C:\>tracert -d 192.168.1.193
Tracing route to 192.168.1.193 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.4.1
2 * * * Request timed out.
3 ^C
PING:
C:\>ping 192.168.1.193
Pinging 192.168.1.193 with 32 bytes of data:
Request timed out.
Request timed out.
Ping statistics for 192.168.1.193:
Packets: Sent = 2, Received = 0, Lost = 2 (100% loss),
Control-C
^C
(Another sample pair, my same PC, and someone else’s PC which has the address 192.168.1.34/24; another sample pair, that other PC, if it happens to get a 192.168.4.0/24 address, and the same Wi-Fi access point; and many other pairs, so I’m fairly confident that it’s my configuration of the MikroTik, which is our LAN’s only router, and not something wrong with one or another node on the LAN).
Someone commented in another thread with this problem that the MikroTik, since it can see both 192.168.1.0/24 and 192.168.4.0/24 on the same physical interface, believes that the clients should be able to do so also, and sends the ICMP Redirect in the interest of making the routing more efficient … but the MikroTik should still be forwarding the packets anyway.
I have put in the MikroTik firewall rule to discard ICMP Redirect packets which the MikroTik wants to send on ether5:
[socialpoint@MikroTik] > /ip fire filt print
0 chain=output action=drop protocol=icmp out-interface=ether5 icmp-options=5:0-255
This definitely stopped the clients from receiving ICMP Redirect messages (and I did remember to flush the ARP tables on the clients first, to avoid them still trying to send directly instead of going through the default router, because of having previously received and been confused by an ICMP Redirect), but nothing changed in terms of the clients’ inability to talk across the 192.168.1.0/24 - MikroTik - 192.168.4.0/24 route.
I can see that the MikroTik is actually forwarding the packets. For example, if I have that other workstation, 192.168.1.34, PING me (192.168.4.21), I do receive the incoming ICMP Echo Request packets. Their source IP address is 192.168.1.34, but their source MAC is the MAC of the MikroTik, not of the sending workstation.
And yet, my workstation doesn’t even try to reply. (I’m watching with Wireshark).
What could the MikroTik be doing when it routes the packets so that although they are received, have the proper source IP address, which is routable by the default route on the receiving workstation, the receiving workstation simply doesn’t even respond?
Here’s a received packet with the interpretation fully expanded in Wireshark:
No. Time Source Destination Protocol Length Info
1261 2012-10-29 15:26:06.233615000 192.168.1.34 192.168.4.21 ICMP 74 Echo (ping) request id=0x0001, seq=129/33024, ttl=127
Frame 1261: 74 bytes on wire (592 bits), 74 bytes captured (592 bits) on interface 2
Interface id: 2
WTAP_ENCAP: 1
Arrival Time: Oct 29, 2012 15:26:06.233615000 Romance Standard Time
[Time shift for this packet: 0.000000000 seconds]
Epoch Time: 1351520766.233615000 seconds
[Time delta from previous captured frame: 0.179143000 seconds]
[Time delta from previous displayed frame: 4.998212000 seconds]
[Time since reference or first frame: 34.972952000 seconds]
Frame Number: 1261
Frame Length: 74 bytes (592 bits)
Capture Length: 74 bytes (592 bits)
[Frame is marked: False]
[Frame is ignored: False]
[Protocols in frame: eth:ip:icmp:data]
[Coloring Rule Name: ICMP]
[Coloring Rule String: icmp || icmpv6]
Ethernet II, Src: Routerbo_d2:c2:79 (00:0c:42:d2:c2:79), Dst: Sony_f3:a9:60 (30:f9:ed:f3:a9:60)
Destination: Sony_f3:a9:60 (30:f9:ed:f3:a9:60)
Address: Sony_f3:a9:60 (30:f9:ed:f3:a9:60)
.... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)
.... ...0 .... .... .... .... = IG bit: Individual address (unicast)
Source: Routerbo_d2:c2:79 (00:0c:42:d2:c2:79)
Address: Routerbo_d2:c2:79 (00:0c:42:d2:c2:79)
Type: IP (0x0800)
Internet Protocol Version 4, Src: 192.168.1.34 (192.168.1.34), Dst: 192.168.4.21 (192.168.4.21)
Version: 4
Header length: 20 bytes
Differentiated Services Field: 0x00 (DSCP 0x00: Default; ECN: 0x00: Not-ECT (Not ECN-Capable Transport))
0000 00.. = Differentiated Services Codepoint: Default (0x00)
.... ..00 = Explicit Congestion Notification: Not-ECT (Not ECN-Capable Transport) (0x00)
Total Length: 60
Identification: 0x24d6 (9430)
Flags: 0x00
0... .... = Reserved bit: Not set
.0.. .... = Don't fragment: Not set
..0. .... = More fragments: Not set
Fragment offset: 0
Time to live: 127
Protocol: ICMP (1)
Header checksum: 0x9063 [correct]
[Good: True]
[Bad: False]
Source: 192.168.1.34 (192.168.1.34)
Destination: 192.168.4.21 (192.168.4.21)
[Source GeoIP: Unknown]
[Destination GeoIP: Unknown]
Internet Control Message Protocol
Type: 8 (Echo (ping) request)
Code: 0
Checksum: 0x4cda [correct]
Identifier (BE): 1 (0x0001)
Identifier (LE): 256 (0x0100)
Sequence number (BE): 129 (0x0081)
Sequence number (LE): 33024 (0x8100)
Data (32 bytes)
0000 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f 70 abcdefghijklmnop
0010 71 72 73 74 75 76 77 61 62 63 64 65 66 67 68 69 qrstuvwabcdefghi
Data: 6162636465666768696a6b6c6d6e6f707172737475767761...
[Length: 32]
No reply is sent by my workstation.
Thanks for your help!
-Jay
