Two userman servers?
Hi i was wondering is it possible to have a backup radius server when using mikrotik radius. So when router1 is down then router 2 takes over.
Yes, just add a second server in the RADIUS tree. If authentication against the first one fails it’ll try the second one.
thank you
Fails as in no responce or fails as in user not found. ?
want to use if radius1 is down,then radius 2 is backup.
This will mean that i have to update both router’s userman configs.
If i could update only radius1 and make is sync with radius2 then that would be nice
Fails as in ‘no response’. If any RADIUS server replies with an ACCESS-REJECT no further RADIUS servers will be checked. Only if no reply is received at all will it move to the second configured RADIUS server.
I don’t think you can do that with User Manager.
