add name=bridge200 admin-mac=DD:EE:FF:AA:BB:CC auto-mac=no
I realize this is an example, but if someone tries to paste the address in, won’t it cause a problem due to it being an ethernet multicast mac (low bit of highest octet is 1)
I just tried in on my RB760iGS, and it looks like RouterOS is smart enough to not allow it, it generated a different mac address CE:90:C4:2E:25:DD
But more to this thread’s point, this extra bridge “solution” doesn’t seem to work. As soon as you add the ether1 to the vlan, the mac address seems to be inherited from ether1. And WinBox won’t let you override the mac address on the vlan interface. So it seems that either I am not understanding, or this won’t work on either v6.48.6 (see the screen shot in @antiqued4 post #10) or v7.2 (see below).
What I think would work, is a second router for the second ASN, I am not running BGP on my hEX S, and I don’t even know if MikroTik supports multiple ASN’s on the same router or not. If so, one possible “fix” would be to use a switch toward the the ISP (CND?) and use the switch to untag the vlans, and then patch them into two ethernet ports, one for each ASN. The point is, the bridge/switch itself won’t change the mac addresses passing through.
Or continue to use the workaround you found, although I don’t know if you may run into weird problems that would be out of “support”.
Following is log on RB760iGS running v7.2
[demo@MikroTik] > /interface bridge
[demo@MikroTik] /interface/bridge> add name=bridge100 admin-mac=AA:BB:CC:DD:EE:FF auto-mac=no
[demo@MikroTik] /interface/bridge> add name=bridge200 admin-mac=DD:EE:FF:AA:BB:CC auto-mac=no
[demo@MikroTik] /interface/bridge> /
[demo@MikroTik] > /interface/bridge/print
0 R ;;; defconf
name="BR-SW" mtu=auto actual-mtu=1500 l2mtu=1596 arp=enabled arp-timeout=auto mac-address=DC:2C:6E:xx:xx:F2 protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=no admin-mac=DC:2C:6E:xx:xx:F2
ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=yes ether-type=0x8100 pvid=1 frame-types=admit-all ingress-filtering=yes dhcp-snooping=no
1 R name="bridge100" mtu=auto actual-mtu=1500 l2mtu=65535 arp=enabled arp-timeout=auto mac-address=AA:BB:CC:DD:EE:FF protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=no admin-mac=AA:BB:CC:DD:EE:FF
ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
2 R name="bridge200" mtu=auto actual-mtu=1500 l2mtu=65535 arp=enabled arp-timeout=auto mac-address=CE:90:C4:2E:25:DD protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=no admin-mac=DD:EE:FF:AA:BB:CC
3 R name="loopback" mtu=auto actual-mtu=1500 l2mtu=65535 arp=enabled arp-timeout=auto mac-address=0E:66:73:AA:10:86 protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m priority=0x8000
[demo@MikroTik] > /interface vlan
[demo@MikroTik] /interface/vlan> add name=e1v100 interface=ether1 vlan=100
[demo@MikroTik] /interface/vlan> add name=e1v200 interface=ether1 vlan=200
[demo@MikroTik] /interface/vlan> /interface bridge port
[demo@MikroTik] /interface/bridge/port> add bridge=bridge100 interface=e1v100
[demo@MikroTik] /interface/bridge/port> add bridge=bridge200 interface=e1v200
[demo@MikroTik] > /interface/print
Flags: R - RUNNING; S - SLAVE
Columns: NAME, TYPE, ACTUAL-MTU, L2MTU, MAX-L2MTU, MAC-ADDRESS
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 S eth4-BR-SW_U10_T241 ether 1500 1596 2026 DC:2C:6E:xx:xx:F4
1 R ether1-WAN ether 1500 1596 2026 DC:2C:6E:xx:xx:F1
2 RS ether2-BR-SW-Base-U1 ether 1500 1596 2026 DC:2C:6E:xx:xx:F2
3 RS ether3-BR-SW-U241 ether 1500 1596 2026 DC:2C:6E:xx:xx:F3
4 ether5-off_bridge_wrk ether 1500 1596 2026 DC:2C:6E:xx:xx:F5
5 S sfp1 ether 1500 1596 2026 DC:2C:6E:xx:xx:F6
;;; defconf
6 R BR-SW bridge 1500 1596 DC:2C:6E:xx:xx:F2
7 R bridge100 bridge 1500 1592 AA:BB:CC:DD:EE:FF
8 R bridge200 bridge 1500 1592 CE:90:C4:2E:25:DD
9 RS e1v100 vlan 1500 1592 DC:2C:6E:xx:xx:F1
10 RS e1v200 vlan 1500 1592 DC:2C:6E:xx:xx:F1
11 R loopback bridge 1500 65535 0E:66:73:AA:10:86
12 R vlan10 vlan 1500 1592 DC:2C:6E:xx:xx:F2
13 R vlan241 vlan 1500 1592 DC:2C:6E:xx:xx:F2
[demo@MikroTik] >
[demo@MikroTik] > /interface/print detail
Flags: D - dynamic; X - disabled, R - running; S - slave
0 S name="eth4-BR-SW_U10_T241" default-name="ether4" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1596 max-l2mtu=2026 mac-address=DC:2C:6E:xx:xx:F4 ifname="eth3" ifindex=10 id=4 link-downs=0
1 R name="ether1-WAN" default-name="ether1" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1596 max-l2mtu=2026 mac-address=DC:2C:6E:xx:xx:F1 ifname="eth0" ifindex=7 id=1 last-link-down-time=apr/06/2022 21:49:27
last-link-up-time=apr/06/2022 21:49:29 link-downs=3
2 RS name="ether2-BR-SW-Base-U1" default-name="ether2" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1596 max-l2mtu=2026 mac-address=DC:2C:6E:xx:xx:F2 ifname="eth1" ifindex=8 id=2
last-link-down-time=apr/11/2022 22:23:30 last-link-up-time=apr/11/2022 22:23:32 link-downs=8
3 RS name="ether3-BR-SW-U241" default-name="ether3" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1596 max-l2mtu=2026 mac-address=DC:2C:6E:xx:xx:F3 ifname="eth2" ifindex=9 id=3
last-link-down-time=apr/11/2022 22:23:16 last-link-up-time=apr/11/2022 22:23:33 link-downs=3
4 name="ether5-off_bridge_wrk" default-name="ether5" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1596 max-l2mtu=2026 mac-address=DC:2C:6E:xx:xx:F5 ifname="eth4" ifindex=11 id=5 link-downs=0
5 S name="sfp1" default-name="sfp1" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1596 max-l2mtu=2026 mac-address=DC:2C:6E:xx:xx:F6 ifname="eth5" ifindex=12 id=6 link-downs=0
6 R ;;; defconf
name="BR-SW" type="bridge" mtu=auto actual-mtu=1500 l2mtu=1596 mac-address=DC:2C:6E:xx:xx:F2 ifname="br0" ifindex=13 id=7 last-link-up-time=apr/05/2022 14:56:55 link-downs=0
7 R name="bridge100" type="bridge" mtu=auto actual-mtu=1500 l2mtu=1592 mac-address=AA:BB:CC:DD:EE:FF ifname="br2" ifindex=17 id=11 last-link-up-time=apr/13/2022 18:17:56 link-downs=0
8 R name="bridge200" type="bridge" mtu=auto actual-mtu=1500 l2mtu=1592 mac-address=CE:90:C4:2E:25:DD ifname="br3" ifindex=18 id=12 last-link-up-time=apr/13/2022 18:20:05 link-downs=0
9 RS name="e1v100" type="vlan" mtu=1500 actual-mtu=1500 l2mtu=1592 mac-address=DC:2C:6E:xx:xx:F1 ifname="vlan13" ifindex=19 id=13 last-link-up-time=apr/13/2022 18:32:03 link-downs=0
10 RS name="e1v200" type="vlan" mtu=1500 actual-mtu=1500 l2mtu=1592 mac-address=DC:2C:6E:xx:xx:F1 ifname="vlan14" ifindex=20 id=14 last-link-up-time=apr/13/2022 18:32:03 link-downs=0
11 R name="loopback" type="bridge" mtu=auto actual-mtu=1500 l2mtu=65535 mac-address=0E:66:73:AA:10:86 ifname="br1" ifindex=16 id=10 last-link-up-time=apr/11/2022 03:19:29 link-downs=0
12 R name="vlan10" type="vlan" mtu=1500 actual-mtu=1500 l2mtu=1592 mac-address=DC:2C:6E:xx:xx:F2 ifname="vlan9" ifindex=15 id=9 last-link-up-time=apr/05/2022 14:56:55 link-downs=0
13 R name="vlan241" type="vlan" mtu=1500 actual-mtu=1500 l2mtu=1592 mac-address=DC:2C:6E:xx:xx:F2 ifname="vlan8" ifindex=14 id=8 last-link-up-time=apr/05/2022 14:56:55 link-downs=0
[demo@MikroTik] > /system/routerboard/print
routerboard: yes
board-name: hEX S
model: RB760iGS
serial-number: xxxxxxxxxxxx
firmware-type: mt7621L
factory-firmware: 6.46.4
current-firmware: 6.47.10
upgrade-firmware: 7.2
[demo@MikroTik] >
