Hello guys, I need to create a redundancy for a client, I put a mikrotik my la, I connected two cables each coming from a different part of the network. I closed VPLS with the two routers, and put the VPLS inside the bridge, along with the port that goes to the customer’s network. If I disable a VPLS everything works, both active, Loop occurs. When using the split horizon in the two VPLS, it even works but if you leave a ping running for example it works and stops and works. Does anyone have any ideas? OBS: I can’t use STP because there are OLT’s that block the broadcast, so it has to be something inside that last Mikrotik before the client.
