I have an issue with a network that has two WAN interfaces and one LAN. They are set as a primary and secondary and will failover upon invoked by a netwatch script.
My issue is that when I want to remote desktop into the secondary WAN interface the port forward NAT rule counts up as if the connection is getting to it, but it isn’t routing back that way (I believe).
Not sure what information I can offer to help you help me, so just let me know =)
Thanks in advance!
/ ip address
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 \
interface="ether2 - LAN" comment="" disabled=no
add address=24.172.x.x/29 network=24.172.148.112 broadcast=24.172.148.119 \
interface="ether3 - WAN4cable" comment="" disabled=no
#this 10.x.x.x private IP has a public IP pointed to it for firewall reasons
add address=10.48.8.70/21 network=10.48.8.0 broadcast=10.48.15.255 \
interface="ether4 - WAN4fiber" comment="" disabled=no
/ ip route
add dst-address=24.29.x.x/32 gateway=24.172.y.y scope=255 \
target-scope=10 comment="Force 24.29.x.x along the main path" \
disabled=no
add dst-address=0.0.0.0/0 gateway=24.172.y.y scope=255 target-scope=10 \
comment="DEFAULT" disabled=no
add dst-address=0.0.0.0/0 gateway=10.48.8.64 scope=255 target-scope=10 \
routing-mark=secondary comment="t1" disabled=no
routing-mark=primary comment="cable" disabled=no
/ ip route rule
add src-address=24.172.x.x/32 action=lookup table=primary comment="" \
disabled=no
add src-address=10.48.8.70/32 action=lookup table=secondary comment="" \
disabled=no
/ ip firewall nat
add chain=srcnat action=masquerade out-interface="ether3 - WAN4cable" \
src-address=192.168.0.0/24 comment="" disabled=no
add chain=srcnat action=masquerade out-interface="ether4 - WAN4fiber" \
add chain=dstnat action=dst-nat to-addresses=192.168.0.2 to-ports=3389 \
in-interface="ether3 - WAN4cable" dst-port=3389 protocol=tcp \
comment="REMOTE DESKTOP TO SERVER" disabled=no
in-interface="ether4 - WAN4fiber" dst-port=3389 protocol=tcp \
