DHCP server - 192.168.11.0/24
DHCP server - 192.168.12.0/24(in the future for guest network)
Router 2: RouterBOARD 951G-2HnD - R2
wlan - “Wi-fi”
port1 - “WAN” 192.168.11.20/24
port2 - “LAN”
wlan2 - VirtualAP (in the future for guest network)
Port1, port2 and wlan are combined BRIDGE. Wireless clients use ip 192.168.11.0/24.
Router 3: RouterBOARD 951G-2HnD - R3
wlan - “Wi-fi”
port1 - “WAN” 192.168.11.30/24
port2 - “LAN”
How to create wireless AP(on routers R2 and R3) for insulated guest network that uses DHCP server(192.168.12.0/24) on the router R1?
Must use vlan?
Please help me. I need manual steb-by-step
That’s what I did:
Router - R1
1)disable “switch mode” for ports 2-5.
2)created bridge1 for ports 2-5.
3)add ip-address for bridge1.(192.168.11.1)
4)created vlan interface on bridge1.(vlan12)
5)add ip-address for vlan12.(192.168.12.1)
6)created new DHCP for guest network.(192.168.12.0/24)
Router - R2
1)created vlan interface on bridge1.(vlan12)
2)created bridge2 for ports vlan12 and wlan2(Virtual AP).
3)add ip-address for bridge2.(192.168.12.2)
4)Configured wlan2 (ssid, password and etc)
Router R3 configured same router R2.
It’s working!
But the guest network is not insulated.
Thought, I decided to add the following rule:
ip route rule> print
Flags: X - disabled, I - inactive
0 src-address=192.168.11.0/24 dst-address=192.168.12.0/24 action=unreachable
1 src-address=192.168.12.0/24 dst-address=192.168.11.0/24 action=unreachable
