Two Wireless with one different network each
I have an RB2011UAS-2HnD-IN route and almost complete configured, but i want to do this config but i am unable to do:
  1. SSID = WLAN1
    WPA with preshared-key = WLAN1-PSK
    network 192.168.1.0/24 (wired LAN on bridge LAN)
  2. SSID = WLAN2
    WPA with preshared-key = WLAN2-PSK
    network 192.168.2.0/24
WLAN1 can see LAN and go to Internet (maybe also see WLAN2)
WLAN2 can NOT see WLAN1 nor LAN but can go to internet (i would like to apply a QoS max 4Mbps Down 1Mbps Up)
LAN and WLAN1 work OK, but i can config WLAN2 in other network (guest network).
Can any give an example of config ?
Thank you.
I would create two VLANs for each WLAN so you are able to separate both from another by using ACLs
and this should working fine for your wishes and set up.
MikroTik RouterOS VLANs
