Hi comunity
Somebody so kind to tell me what is the max TX Power that “Mikrotik Lhg Xl 5 Ac 802.11a/n/ac” supported.
I haven’t found it on mikrotik/manuals/stackoverflow etc… ![]()
Thanks in advanced
Hi comunity
Thanks in advanced
Did you check downloads page?
https://mikrotik.com/product/lhg_xl_5_ac#fndtn-downloads
There is brochure available.
Also, correct me if I am wrong, but TX Power is something you should not be looking for when choosing a wireless device: https://www.draytek.co.uk/support/guides/difference-between-db-dbm-dbi
It is in the specs list … https://mikrotik.com/product/lhg_xl_5_ac#fndtn-specifications
Wireless specifications
5 GHz Transmit (dBm) Receive Sensitivity
6MBit/s 25 -96
54MBit/s 21 -80
MCS0 25 -96
MCS7 20 -75
MCS9 18 -70
And the used TX power will depend on the region.
If you live in a region where the max EIRP is 27 dBm, with the antenna gain of 27 dBi, the maximum used TX power will be 0 dBM ! (or 1 milliwatt)
@erkexzcx I know
TX parameter help me a lot with my configuration, I meant TX has improved my wireless network.
But 've read in some posts that is a dangerous parameter.
