Tx Power Output Values
What are the Tx values in Mikrotik equal to? for example what does the value 1 mean?
AFAIK, the power is in dBm. see the example below; I hope this information is helpful. My apologies if I didn’t understand your question.
The output is for a R52:
current-tx-powers: 1Mbps:20,2Mbps:20,5.5Mbps:20,11Mbps:20
rgds/ldv
[vaden@dd-car1-ap4] > /interface wireless
[vaden@dd-car1-ap4] interface wireless> print
0 R name=“local” mtu=1500 mac-address=00:0C:42:05:35:28 arp=enabled
disable-running-check=no interface-type=Atheros AR5413
radio-name=“000C42053528” mode=ap-bridge ssid=“Internet Texoma” area=“”
frequency-mode=manual-txpower country=united states antenna-gain=8
frequency=2457 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=1s
on-fail-retry-time=1s preamble-mode=both compression=no
allow-sharedkey=no
[vaden@dd-car1-ap4] interface wireless> monitor 0
status: running-ap
band: 2.4ghz-b
frequency: 2457MHz
noise-floor: -97dBm
overall-tx-ccq: 100%
registered-clients: 22
authenticated-clients: 22
current-ack-timeout: 90
current-distance: 90
nstreme: no
notify-external-fdb: yes
yes, it is in dBm, but i suggest to leave this setting to default as the card will run at the power that is written in it’s EEPROM (the manufacturers recommended value). use it only to lower the power, not to increase it, as overheating will reduce the performance.
IIRC, the default value chosen by RouterOS 2.9.30 for the R52 is 20, vs. the 19 dBm quoted on the data sheet for the R52, correct?
rgds/ldv
