i tested my link using bw test.
I did the following tcp protocol test:
Only RX:22Mbps
Only TX:22Mbps
Both
TX:8Mbps
RX:18Mbps
I can’t understand why in both modality the values are so different!
Thanks,
Levis
Only RX:22Mbps
Only TX:22Mbps
Both
TX:8Mbps
RX:18Mbps
Thanks,
Levis
Look at your CPU usage…
When you Rx or Tx it comes up to a 100% and you get 20Mbps (100% CPU = 20Mbps)
But when you do both you can get ex. 16Mbit Tx and 4Mbit Rx at a 100% CPU…
And you get 26Mbit and that’s nice IMO…
but I prefered 10Mbps in tx and 10Mbps in rx!
Thanks.
Add a Simple Queue
Something like this:
/queue simple
add max-limit=10000000/10000000
but this link is shared, it’s used from several pppoe user.
Do I need tuning better both antennas?
Levis
What are your signal strengths, CCQ and noise floor on each end of the link?
Base 1 :
Tx/Rx SS: -66/-66 dBm
Noise Floor: -100dBm
Tx/Rx CCQ: 60/53%
Base 2 :
Noise Floor: -94dBm
Tx/Rx CCQ. 87/???%
CCQ is your problem…
in base 1?
I have to tuning better end 1?
thanks…
Have you changed frequencies? Might be interference…
I’ll try asap…
thanks
