hello,
please assist me on thi issue:
i have RB532/SR5 on point to point setup. it has been working fine for about a month now. but suddenly i cannot ping the two radios again. after so many hours of troubleshoting i noticed that RX/TX CCQ on both radios are not reading and mt signal to noise ratio became very low.
below is result i got from registration-table print stats.
Terminal vt102 detected, using multiline input mode
[admin@MikroTik] > /int wire
[admin@MikroTik] interface wireless> registration-table pr
INTERFACE RADIO-NAME MAC-ADDRESS AP SIGNAL... TX-RATE
0 UST_wll phc_garrison 00:15:6D:10:12:E3 yes -90dBm... 6Mbps
[admin@MikroTik] interface wireless> registration-table print stats
0 interface=UST_wll radio-name="phc_garrison" mac-address=00:15:6D:10:12:E3
ap=yes wds=no rx-rate=6Mbps tx-rate=6Mbps packets=55194,47979
bytes=3966260,3710137 frames=55194,49037 frame-bytes=3641846,3433825
hw-frames=58500,49052 hw-frame-bytes=5270189,4611103 uptime=17m44s
last-activity=10ms signal-strength=-89dBm@6Mbps signal-to-noise=16dB
strength-at-rates=-89dBm@6Mbps 10ms tx-signal-strength=-90dBm tx-ccq=25%
p-throughput=5857 ack-timeout=28 distance=28 nstreme=no framing-mode=none
routeros-version="2.9.24" last-ip=192.168.16.204 802.1x-port-enabled=yes
authentication-type=none encryption=none compression=no
[admin@MikroTik] interface wireless> pr
0 R name="UST_wll" mtu=1500 mac-address=00:15:6D:10:11:CA arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name="sonnet_ust" mode=station ssid="sonnet003" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=5800 band=5ghz-5mhz scan-list=default rate-set=default
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic
tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-b wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no
[admin@MikroTik] interface wireless> mon 0
status: connected-to-ess
band: 5ghz-5mhz
frequency: 5200MHz
tx-rate: 6Mbps
rx-rate: 6Mbps
ssid: "phc003"
bssid: 00:15:6D:10:12:E3
radio-name: "phc_garrison"
signal-strength: -89dBm
tx-signal-strength: -91dBm
noise-floor: -104dBm
signal-to-noise: 15dB
tx-ccq: 21%
p-throughput: 5857
current-ack-timeout: 28
current-distance: 28
wds-link: no
nstreme: no
framing-mode: none
routeros-version: "2.9.24"
last-ip: 192.168.41.170
802.1x-port-enabled: yes
authentication-type: none
band: 5ghz-5mhz
frequency: 5200MHz
tx-rate: 6Mbps
rx-rate: 6Mbps
ssid: "phc003"
tx-signal-strength: -90dBm
signal-to-noise: 13dB
tx-ccq: 26%
p-throughput: 5857
wds-link: no
nstreme: no
framing-mode: none
last-ip: 192.168.41.242
band: 5ghz-5mhz
frequency: 5200MHz
tx-rate: 6Mbps
rx-rate: 6Mbps
ssid: "phc003"
tx-signal-strength: -89dBm
tx-ccq: 21%
p-throughput: 5857
wds-link: no
nstreme: no
framing-mode: none
last-ip: 192.168.41.168
band: 5ghz-5mhz
frequency: 5200MHz
tx-rate: 6Mbps
rx-rate: 6Mbps
ssid: "phc003"
tx-ccq: 27%
p-throughput: 5857
wds-link: no
nstreme: no
framing-mode: none
last-ip: 192.168.41.186
band: 5ghz-5mhz
frequency: 5200MHz
tx-rate: 6Mbps
rx-rate: 6Mbps
ssid: "phc003"
signal-to-noise: 14dB
tx-ccq: 22%
p-throughput: 5857
wds-link: no
nstreme: no
framing-mode: none
last-ip: 192.168.41.176
Can anyone help assist me on the solution to this problem.
