Tx/Rx CCQ problem
hi guys,i am a beginier in all this…my router getting very gud Tx/Rx Signal Strength (-79/-73 dBm) but my connection is not stable and i think i m getting this problem coz of Tx/Rx CCQ unstablity. plz guys help me out. :confused: :confused: :confused:
My signal strenth is:Rx Signal: -73 dB
Tx Signal: -79 db
why nobdy is replying me? :confused: :confused: :confused:
CCQ values will be low if there is no traffic on the wireless link.
Try to push traffic over the wireless link and check again.
can u plz tell me how can i push traffic on wireless link…i beginier in all this …plz sir guide me step by step :confused: :confused: :confused:
here is one link to the wiki page how to make bandwidth test between the mikrotik devices:
http://wiki.mikrotik.com/wiki/Manual:Tools/Bandwidth_Test
i just want to config my upload speed which is to high…i am getting 1.5 mbps download speed which is gud, but i m also getting 1.5mbps upload speed…which causes me unstable net connection…plz tell me how i can change my upload speed? i want low upload speed around 512kbps…can nybdy tell me how to do this?? :confused: :confused:
Try to re-orient antennas in better way and be sure you do not have any obstacles on the way. Also check if there is another available frequency to select.
i have tried 2 more frequency bt no luck…can i downgrade my upload speed using winbox if yes thn plz tell me how? :confused: :confused:
dont tell me this forum is closed…nybdy thr?..nobdy rplying me :confused: :confused:
