You know, anywhere else the above would sound wrong… but here… ![]()
I’m probably being thick and making this more difficult than it is, but… here it is.
My company has around 100 locations throughout the country.
At each location we have a LAN with a unique subnet… ex: 10.40.34.0/24 would be a location in South Bend Indiana. The home location is 10.40.1.0/24. They are connected via IPSEC VPN tunnels Regionally, and then from there Nationally.
At each location we have a Windows 2003 R2 or 2008 R2 File and Print Server that acts as that location’s “home” server. Regionally we have Exchange 2003 or 2010 servers, so for every 10 locations or so, there’s an Exchange server somewhere that their email lives on.
So, at each location we have The Dude running on the server, and we have the key components (printers, wireless access points, etc.) being monitored. We’re looking to build a master map.
If we had one dude server at corporate with multiple (local) maps that monitored everything, we’d likely kill the VPN network with monitoring traffic, which is why we implemented the solution we did.
What I’m aiming for is basically what a submap object looks like, but where the map isn’t on the local machine.
I see where I can add a remote Dude as an agent, but I can’t seem to get the “Submap summary” view (where it says 40 / 0 / 0, for instance).
I can click the lightning bolt in the top left corner, enter the remote dude’s IP address, username, and password, and then I can look at the map on that remote dude, but I don’t want to be doing this for 100 dude servers every day.
Is there something I’m missing here? Did I not RTFM enough?
Thanks, in advance!
