tzsp runing 2-3 days,will nothing to send.and disable the tzsp rule 1s to enable,can solve. ![]()
in 6.31
Is the interface you are capturing the traffic from static or dynamic?
from static becouse capturing all lan traffic.send to static ip.and i try to disable one tzsp rule can’t to solve,must to disable all tzsp can solve this.but after 2-3 days will too.this tzsp recv client at other network.send traffic on internet,maybe isp problem.now i add tunnel to do it,and see later.
