where can we find hdds for rds2216 in europe?
The SSD-U2-7-1TB that was at a normal price got discontinued.
I am using an adapter to nvme at the moment but it is not the ideal solution and I am about to buy 2 more rds2216
I've been looking at acquiring an RDS2216 myself but the drives are either out of stock or marked end of life everywhere I've found on a search. I live in the United Kingdom.
U.2 drive alternatives are out there but as it's a specialised product in a market already inflated by the AI crisis I've only seen drives that cost as much if not more than the RDS2216.
Would've been a cool project but l've abandoned it on the face of the cost and also mounting it in a SolidRack 10 is probably a bad idea.
Samsung PM9A3 maybe? You could try using U.2 to M.2 adapters too.
List price is (was):
https://mikrotik.com/product/ssd_u2_7_1tb
US$219
look like 4x-5x that price.
forget about cheap SSDs for the next 5 years or so
I think that a large part of the issue Is the 7 mm thickness format.
StarTech makes U.2 to M.2 adapters that should fit (search for U2M2E125).
I am using startech's adapter already to 10+ drives but I was about to buy the u.2 of mikrotik and noticed that it is discontinued and I was looking for an alternative
