Dear MikroTik Support Team,
We are currently developing a UAV (Drone) Swarm project consisting of 5 drones and 1 Ground Control Station (GCS). We have selected the MikroTik Groove 5ac as our primary communication hardware for both air-to-air and air-to-ground data links.
Our system architecture relies on Nvidia Jetson Nano companion computers and Pixhawk flight controllers. Our primary goal is to establish a highly reliable, low-latency Mobile Ad-hoc Network (MANET) for MAVLink telemetry (UDP) data. If a drone loses direct Line-of-Sight (LoS) with the GCS, we need the system to dynamically route the data through other drones (relaying) with minimum interruption.
We have a few technical questions regarding the optimal configuration for this specific use case:
Can we achieve a highly dynamic mesh network (e.g., using HWMP+ or 802.11s) directly with the default RouterOS firmware, or does it require installing additional custom packages? Is the system essentially "plug-and-play" once the initial mesh interface and ports are configured?
Considering the nodes (drones) will be highly mobile and the network topology will change rapidly, which wireless protocol do you recommend for the fastest topology convergence and lowest latency? (Standard 802.11, NV2, or Nstreme?)
Does the default RouterOS license level included with the Groove 5ac fully support our 6-node (5 Drones + 1 GCS) full-mesh topology without any routing restrictions?
Since we are using UDP broadcast/multicast for our swarm communication, are there any specific RouterOS settings you recommend to prevent network flooding and keep the latency at a minimum?
Would it be most suitable for us to run this system in QGroundControl, Mission Planner, or an external application? What would you recommend? We need to be able to see all five drones at once from a single interface.
Any insights, specific Wiki documentation links, or best practices for aerial MANET applications would be highly appreciated.
Thank you for your time and support.
Best regards,
ITUNOM UAV TEAM/ Arda Turan
