it is possible reads by snmp frequency from ubiquiti ap?
i can only read by snmp oid from client
“iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrWireless.mtxrWlStatTable.mtxrWlStatEntry.mtxrWlStatFreq.5”
Make snmp walk over all values and you will see if it is published or not.
ubnt 5.5.8 doesnt give information about frequency at ap side, but give it at client side. it is possible get by snmp info about frequency from client and display it at ap icon at dude map? how i can do it?
It is unlikely that the client actually adds a SNMP value of the frequency to the operating system snmp values… if it does it might work in one OS but not another. In Windows and Linux you can enable SNMP (ask google) and walk the computer after adding it to the Dude to see the SNMP values that the operating system populates, to have more values populated in SNMP this is usually done by yet another program running in the OS that creates an additional OID in the vendor specific OID and populates those values. Disclaimer, It is not going to be worth your time.
Lebowski
hello, you can do it if you have the latest firmware installed.
Frecuency: [oid(“1.3.6.1.4.1.41112.1.4.1.1.4.1”)] Ghz
