Hy. From Ubiquiti www site, you can view this PDF: http://www.ubnt.com/downloads/SRXR_power_offset.pdf.
On that PDF, the declared offset between manual txpower and real txpower, is +10dB for SR2 and XR2.
then why should i buy and give proposal for 600mw??
lets say 200mw and finish
FYI i uesd and tried 500mw overboost it to 29dbm working up and stable as rock for 5 days now
why is taiwan engineer better than USA Engineer???
why all this advertisments on the ubnt hardware?
why should i pay alot of money for GSM rejection and bala bala bala
Can anyone from you guys tell me why is 2.9.38 is diffrent than 2.9.42???
if you could tell me i will be greatfull ![]()
Why on a cloudy day is the sky grey?
Why on a clear sunny day is the sky blue?
Clear days are not necessarily better than cloudy days.
Some people move thousands of miles to environments where it is cloudy most days of the year.
Why is this?
In the case above some people have skin conditions, and the clear sunny days can KILL them.
2.9.38 is prefered by some, and 2.9.42 is prefered by others.
42 is supposed to be an enhancement on 38, but sometimes enhancements impede on older features, etc.
Preference ultimately comes down to the requirements, and not much more than that.
600mw radios solve many problems, they can also create problems.
200mw radios are quite capable, and versatile, but not necessarily robust enough.
EDIT:
Although many of the products come from taiwan, does not mean the engineering was done there!! Much of the engineering comes from US, Europe, and Canada.
keep in mind guys that i really like mikrotik and ubnt hardware but i m looking for a fix
btw tgrand do you have XR-2 installed and running??
To: taloot
one thing i want to know is it really work gr8 for you guys??
YES! it works great. 24 hours a day 7 days a week.
where is mike-ubnt he gone?
Don’t know! I never have problems so I don’t need him.
why its good in indoor and extremely baaaad on outdoor?
Humm, I use them for hotel hotspots and ptmp outdoor networks.
so the SR2 and XR2 is uesless??
NO! again their great cards for me ![]()
I’m not sure why you are having these problems. It’s just to hard to guess. I do know that I have tried all kinds of cards and the SR2 and SR5 have been better in big cities, hotels and rural areas.
Now sure I’ve had problems here and there but I have always found a way to make things work. Now that most of my CPEs and all of my APs are Mikrotik with Ubiquiti, I don’t have a network that make me crazy. It just works. Hell, I even go on two week vacations without worrying about the network going down.
Hi jober,
Can you please tell us more about your setup?
I would like also to have a vacation without problems!!! ![]()
Bye
Agreed completely. We use XR2s outdoors in PtMP networks, works great.
I talk to Mike at UBNT probably three times per week, he’s easy to reach.
Our network (over 600 MTs now) works very well. CM9s, RB52s, XR2s, SR9s, SR5s, mainly on RB hardware. Still some legacy Trango, some legacy x86 hardware, but less all the time.
Only get problems with severe icing or lightning, otherwise it just works.
The ONLY thing that peeves me about MT is their insistence on building for their own hardware, then being slow about it. I covet the ADI Metro boards, but I guess we will get an equivalent eventually.
George
Yes,
I am having GREAT success using these cards.
They work FLAWLESSLY.
I had some issues with an ROS version and 5MHz wide channels using these cards, but not an issue with the hardware.
Running them on 9dbOmnis with 7deg downtilt.
noise floor is <-100 on all my units in area where there are 3-4 Wisps.
Have had links of 15Kms to these access points using nothing more than an LS2 and a 15dB panel, with no problems.
The area is well treed.
Several Antenna support structures with an AP on each one.
All work flawlessly.
KO, Humm, where do I start?
My APs are Rb532s and they have two radios, one SR2 and one SR5, these are connected to RadioWave DualBand 90* sector antennas (the ant. has two N type connectors one for 2.4 and one for 5.
. Most of my towers have 48Vdc ran up them with RF cable to power the radios and switch’s. I don’t bridge much of anything anymore. I’m not saying it’s bad, Just that I don’t do it to much. I have the Data rate set to 24 on the AP and CPEs. I use 10mhz on the 5.8 APs and 5mhz 2.4 APs except for the Hotspot which use 20mhz on ch1 and 11. Channel 6 is broke into 4X5mhz over 4 sectors.
We route the whole network with a little help from ospf. each AP radio has it’s own private /24 and the main router too. The main router has NAT and ospf setup with some firewall rules to route the /24 of publics to the customers. The APs have the access list to lock the speeds down.
The CPEs are all being install the same way now. For these CPEs we use RB532s with a SR5 or now XR5 with a 24dbi panel to connect to the tower and then we have a SR2 or XR2 with a 9dbi omni for the hotspot. The CPE have a public /32 IP and the preferred source is set to that with the gateway being the private network. This was just a way for us to save IP’s. We did have every thing running on public IP’s and they were broke up all over the place. It was not easy to wrap my noodle around this network design but with Gerard’s help setting it all up it seems so easy now. LOL NOT!
Anyway, moving on to New Orleans.
I have a little different setup in the big easy. The noise floor sucks, so I use 24dbi panels and 26dbi grids for all the APs and the radios are all 5.8, two per board. The boards I use there are VIA500mhz fanless x86 with a PCI to mini-PCI adapter. When MT gets the new high power boards out I may change the VIAs to them. I have two of the APs running nstreme with polling because I don’t have a lot of customers on them. I guess they are in beta testing mode. hehe
All the APs there run 10mhz as well and I don’t use 2.4Ghz for ptmp there at all.
I use Dual Nstreme there for the main uplink which has been great. Never any problems at all.
The CPEs are the same but I use 29dbi grids insted of the 24dbi panels.
In New Orleans The only thing I have found to be a problem it that compression can stop the IP traffic. I could still mac ping but not IP ping. I had to turn it off on some AP’s.
In Covington I have one AP radio that I have to keep at B only because the two CPE’s that are not MT won’t connect in G mode. Oh, and when they are trying to connect the pings go to hell.
As you can see I don’t do anything magical or to fancy with the network. But I have found that having all your hardware the same makes life a lot easier. I started building my network in th e90’s and the only thing I could get was 2meg radios. I tried every new radio that came out and before I know it I had a network of all kinds of cheap shit. Let me tell you, thats the wrong way to go. It drove me nuts till MT came along. Now I can stay with the same board and software and I only have to change the radios if something new comes out. I HOPE! LOL
PS. Life is just a crap shoot!
thanks but simply guys what version u are using???
why is 2.9.38 more stable than 2.9.42 in 3 locations
i uesd it in point to point all mikrotik rb133 xr2
nstreme doesnt work for me @ all on 2.9.42 just in version 2.9.38 works gr8 is that ringing a bull???
btw guys you remeber 1 year ago when i post some of my problems and all people here is saying everything is ok but after later relase in mikrotik things getting improved
my fainal word is
2.9.38 is more stable than 2.9.42 can anyone deny this?? i m ready to place my bit
Aside from some older versions we haven’t felt the need to upgrade, we run on 2.9.30 and 2.9.42.
Wireless generally seems a little better on .42.
Both are very stable.
George
i hope everything is going fine and stable
and i wish from mikrotik to resolve some issues in wireless
i have descition with some guys in the forum that they agree with the 2.9.38 is much much stable espacilly on SR2
in XR2 also see some improvments
i m not talking like this becouse i hate UBNT or Mikrotik, but i feel that its very importnat to tell that i faced problem for both of them
and i dont think that i m stupid and missed up the LINK
in indoor the AP working gr8 for oudoor its not noisefloor is -104
signal is high
i did say that all the low power mini-pci work stable with 2ms pinigng in both 42 and 38 except the nstreme it doesnt work for me in 42
thats all what i have to say
I have 2.8.28,2.9.38, 2.9.40 and 2.9.42. most are 2.9.42.
Yes I do remember you bitching about the senao cards not working and when the new version came out it didn’t say anything in the change file about the wireless being fixed but for some strange reason the cards started working better. Not that I would ever use them again but yes you did.
I don’t have any problems with the Ubiguiti cards AT ALL!
If I may ask, what kind of CPE’s are you using?
I don’t doubt your problem I just don’t have as of now, but who knows there’s alway tomorrow! So hurry up and get it fixed so I don’t have this problem too.
Anyone having problems with the Ubiquity radios?
Humour me.
Try disabling the hotspot, and simply use the Access Control List to test things over a few hours.
Post your results when you have done this.
What does the hotspot have to do with it?
I have hotspot service on all my clients using the SR2 or XR2 cards.
So do I.
I have had instance where One of my AP’s is suddenly having problems.
I have disabled the hotspot, and all appears to be OK.
The clients did not disassociate (I thought that at first), just traffic stops, and only from the AP, as I have a Backhaul whos traffic flows through this RouterBoard 532, and the backhaul data continues to traverse correctly.
The Client traffic contines after a 10 Minute stall. The stalls occur at random times.
I have even replaced the XR2, with no change in results.
I am contemplating replacing the RB532, but am not convinced it is a hardware problem.
Humm, I had a few clients with SR5’s stop passing traffic, but I could still mac-telnet in to the units. Now, what I found was that compression was the problem. If I turn compression off traffic would start moving again. And if I left it off the problem wouldn’t come back.
I do have hotspots running on all the clients, but not on any of the main APs that the clients connect to. I don’t because I can’t have some guy sitting in his car with a shit signal killing the connections of my main clients.
Anyway I hope you guys get these problems fixed real soon.
Good Luck ![]()
