Ubiquity Customer Bandwith Usage
I can see bandwidth usage on Eithernet 1, 2, 3, etc.
I can chart each one.
I can map the entire network and see all of the radios
I can ping all of my Ubiquity radios
SNMP is set on the computer
SNMP is set on the Microtik
SNMP is set on all of the APs and Client radios
What do I need to set to be able to chart each radio and see bandwidth usage for each radio??
Thanks, Mike
The easy way to do this is to add a static, add a link between the AP and static then select the radio interface inside the link SNMP settings.
I’m new to Dude and need a little more detail please.
Add a static where and how?
I see Links on the menu but can’t do anything with it without the static.
Thanks much, Mike
I was out last week…
To add a static right click on the map, select add static. To add a link between the AP and static, right click on the map select add link.
Connect the link by clicking on the first device and dragging it to the 2nd device. “Drag the link between them.”
HTH,
Lebowski
