Ubiquity SuperAG on PS5<-> MT XR5 How to ?
I can’t find any references in the manual or the forum on how to use superAG features in MT.
As the feature is available in Ubiquiti’s 5Ghz gear I was wondering if there are settings in MT to allow interoperation ?
Is nstream the MT equivilant ?
In that case will it interoperate?
Any advice ?
I have turned on the SuperAG features in a wds backhaul between 2 NS5’s and it added a third more throughput in real world transfers!
Cheers.
/interface wireless set wlan1 band=5ghz-turbo
Thanks for your reply but from what I can understand so far the superAG features ie framer, bursting and compression can be enabled in both Mt and Ubiquiti without 4omhz channels.
Certainly in the setup I’m running between the 2 NS5’s I am not running 40mhz channels and the performance gains are clear.
