We have some (problematic) towers where is very important db loss and a very fast replacement of radio.
We want to try the following solution:
- using of ubnt bullets attached directly to antennas (two each antenna, double pol):
- pro: avoid cable loss (avoiding RF cables), fast replacement, cheap, redundancy, ?
- cons: cannot use nstream, ?
- at the bottom of the tower two RB493AH in VRRP:
pro: fast replacement, cheap, redundancy, ?
cons: ?
the bullets are simply configured to bridge two remote rb493 ports and used only for ptp links
sectors will be linked to a mikrotik access point (we love nstream)
I calculated the total price is the approx same as using a case with rb411ah and rb52 for each antenna, without using rb493ah.
Could someone suggest new pro and cons of this architecture ?
thanks
