UBNT UNMS with Traffic Flow
UNMS is supporting NETFLOW
This router is supporting 500 Customers if I enable Traffic flow on the Mikrotik Cloud core will it create a reboot?
any issues to be aware of?
running 6.34.4
yes I know its way outdated I have a 2nd unit with config and updated firmware we just can’t afford downtime yet
Thanks,
If the package is disabled then you would need to reboot after enabling it before it will start working, but a reboot will not happen automatically.
If the package is enabled, you should be able to configure it without needing to reboot.
