UDP Across IPSEC VPN
Hi Again all,
I’m trying to get UDP packets to traverse a IPSEC tunnel with NAT-T.
Using IP Sec we change addresses for traffic across the Tunnel to masq the NAT connection as per http://wiki.mikrotik.com/wiki/Manual:IP/IPsec
Site 1.
IP: 172.16.10.1 - LT2P 10.0.1.9
Site 2
IP: 172.16.11.1 - LT2P 10.0.1.10
I can see traffic identify itself on either side using torch such as the clients within the network.
172.16.10.11 - 172.16.11.5
and I can get SMB, HTTP and all TCP services to work.
But it appears as if UDP traffic is not establishing some communication. So if I run a bandwidth test on UDP from router to router, I see one burst of UDP but no connection is setup and bandwidth test doesn’t work. It works fine of course with TCP. What am I missing to allow UDP to traverse this link for bandwidth test and other UDP protocol requirements.
Thanks :slight_smile:
Can we get a look at your IPSEC & NAT setup.
Regards
Andrew
