udp again
Hi.
My last post on this subject has stalled, so I'll try again.
I'm using an RB751U-2nHD running RouterOS 5.16.
I have performed a hard reset on the router and confirmed I'm back to the factory settings.
I have a simple UDP server and corresponding UDP client. On my home network and my work network this pair of apps works well together - the client sees every UDP packet sent by the server.
When I try to run the same apps from 2 different PCs through the RB751U I get no throughput, ie the client never sees any UDP packets.
How do I configure RouterOS to allow throughput of UDP packets?
I have searched the docs, google, etc, and so far have come up with nothing.
Here is my "export compact" config output:
jan/02/1970 00:04:19 by RouterOS 5.16
software id = 4KEY-3ISZ
add admin-mac=D4:CA:6D:67:1B:BB auto-mac=no l2mtu=2290 name=bridge-local
protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=
indoors ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=ap-bridge
wireless-protocol=any
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=
bridge-local
/ip dhcp-client
add comment="default configuration" disabled=no interface=ether1-gateway
add address=192.168.88.0/24 comment="default configuration" dns-server=
192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=
ether1-gateway
add action=masquerade chain=srcnat comment="default configuration"
out-interface=ether1-gateway
/ip neighbor discovery
set ether1-gateway disabled=yes
set wlan1 disabled=yes
/system leds
set 0 interface=wlan1
/tool mac-server
add disabled=no interface=ether2-master-local
add disabled=no interface=ether3-slave-local
add disabled=no interface=ether4-slave-local
add disabled=no interface=ether5-slave-local
add disabled=no interface=wlan1
add disabled=no interface=bridge-local
/tool mac-server mac-winbox
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=wlan1
add interface=bridge-local
TIA
FWIW the 2 computers running the client and the server are connected to routeros wirelessly. I have confirmed they have properly allocated DHCP addresses from the router.
