UDP blocked over VPN issue
I have a simple network with a device streams UDP multicast data and a Mikrotik router. An additional laptop is physically connected to one of the LAN ports of the router and is able to connect to the router’s VPN (PPTP server).
The laptop is able to send and receive TCP packets through the VPN, but not UDP packets. Is there something I’m missing on my configuration?
# jan/02/1970 00:05:42 by RouterOS 6.42.11
# software id = LEFN-C042
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 8A7A09F8E867
add admin-mac=B8:69:F4:35:1A:CF auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    country=canada distance=indoors frequency=auto mode=ap-bridge ssid=\
    MikroTik-351AD5 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-Ceee country=canada distance=indoors frequency=auto mode=\
    ap-bridge ssid=MikroTik-351AD4 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.0.10-192.168.0.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
add bridge=bridge comment=defconf disabled=yes interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ether1
/interface l2tp-server server
set enabled=yes ipsec-secret=lol use-ipsec=yes
add interface=sfp1 list=WAN
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.0.1/24 comment=defconf interface=ether1 network=\
    192.168.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=sfp1
add address=192.168.0.0/24 comment=defconf gateway=192.168.0.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.1 name=router.lan
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    established,related,untracked
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=accept chain=forward protocol=udp
add action=accept chain=input protocol=udp
add action=accept chain=output protocol=udp
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
    192.168.89.0/24
/ppp secret
add name=vpn password=lol
Thank you,
Alpheratz
The problem is not UDP but that it’s Multicast
Check this post by @doneware and the whole thread.
-Chris
