UDP Broadcast forward
Hi, I’ve a router MikroTik RB2011iL-IN.
I try to use a simple discovery protocol: master from WAN (external network…like IP 10.20.32.xx) send a UDP broadcast packet (255.255.255.255) on port UDP 12233, LAN clients (internal router subnet with NAT…like IP 192.168.88.2xx) receive the message and send a response on port UDP 12234… The router has a default configuration and blocked the messages…Is there any setting to enable into the router this functionality? (I can not switch the router modality to bridge mode)
thank you!
Alberto
