Hi.
I’ve played around with home networks successfully, but I’m new to routeros and more detailed networking configurations. My background is application development, not network administration.
I’m using an RB751U-2nHD running RouterOS 5.16.
I have a simple udp server and client that I’m using to test network configurations. When I run this on my work or home network it works just fine, but when I tie the client and server computers into my MikroTik router there is no communication between the 2 pcs. I have done this hard wired and wirelessly, with the same results. Both computers are correctly getting their DHCP addresses from the router, FWIW, so I know they see the router ok.
I have done some searching in the docs and on google, but I have yet to find a direct answer to my issue. I can’t believe I haven’t found the answer yet so I must be overlooking something obvious.
I would greatly appreciate any advice/pointers to help me get past this. If this has been posted before then please just post the link to the answer. Thanks in advance.
Post your config (output from /export compact) with a note of which ports the relevant devices are attached to.
Thanks for responding. This will probably reveal what a noob I am. I'm seeing some errors near the bottom of this output. During the output of this both computers were connected wirelessly.
[admin@MikroTik] /interface wireless> /export compact
jan/02/1970 05:16:14 by RouterOS 5.16
software id = 4KEY-3ISZ
add admin-mac=D4:CA:6D:67:1B:BB auto-mac=no l2mtu=2290 name=bridge-local
protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=
indoors frequency=2422 ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=
ap-bridge ssid=SimplyMWD wireless-protocol=any
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=default-dhcp ranges=192.168.88.20-192.168.88.137
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=wlan1
add address=192.168.88.0/24 interface=ether2-master-local
add address=192.168.88.2/24 interface=wlan1
add address=192.168.88.3/24 interface=wlan1
add address=192.168.88.4/24 interface=wlan1
add address=192.168.88.5/24 interface=wlan1
add address=192.168.88.6/24 interface=wlan1
add address=192.168.88.7/24 interface=wlan1
add address=192.168.88.8/24 interface=wlan1
add address=192.168.88.9/24 interface=wlan1
/ip dhcp-client
add comment="default configuration" disabled=no interface=ether1-gateway
add address=192.168.88.0/24 comment="default configuration" dns-server=
192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=
ether1-gateway
ether1-gateway
add action=masquerade chain=srcnat comment="default configuration"
out-interface=ether1-gateway to-addresses=0.0.0.0
/ip neighbor discovery
set ether1-gateway disabled=yes
set wlan1 disabled=yes
/system leds
set 0 interface=wlan1
/tool mac-server
add disabled=no interface=ether2-master-local
add disabled=no interface=ether3-slave-local
add disabled=no interface=ether4-slave-local
add disabled=no interface=ether5-slave-local
add disabled=no interface=wlan1
add disabled=no interface=bridge-local
/tool mac-server mac-winbox
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=wlan1
add interface=bridge-local
Hi.
Any ideas?
Someone else (offline from here) suggested bridging all interfaces together. For lack of a better idea I’m looking into that now.
Thanks.
