UK 4G Support
I’m UK based, and am trying to work out the best solution to connect a MT router to a 4G connection (I would welcome suggestions for other USB modems that are known to work in the UK).
I’m currently looking at using EE as a service provider, who support the Alcatel L800 USB modem. Has anyone used this model of modem with a MT router successfully?
Thanks in advance.
The Alcatel isn’t on the compatibility list http://wiki.mikrotik.com/wiki/Supported_Hardware.
I’ve ordered a Huawei e3272 to try in a Mikrotik 750UP. I’ll be using an EE SIM. Will let you know how I get on.
Steve
The e3272 works fine.
Steve
