UK Lease line WAN subnet mask on MK routers
Hi
Dealing with UK lease line WAN circuit suppliers (well BT and Virgin) I always have to program the WAN interface of the MK with a mask of at least /29 (and sometimes /28) where as the documented subnet mask from the supplier is always 255.255.255.254 (/31). The Aggregation router is always the next ip up. CPE IP x.x.x.246 and AR IP x.x.x.x.247 yet I can only ever bring up the route if I use /29 (/28) as the network mask.
Anyone else have this issue? Its never been a problem because Ive never had a customer with two circuits in the same location at the same time but one day Im going to hit a hurdle of having another circuit on say .248 (in the above example) and Im not going to be able to route to it.
Tim
I seem to remember a thread or two on this forum where users complained about MT not allowing /31 netmask (if you think of it, it doesn’t seem like valid netmask as it lacks network and broadcast addresses). But there’s a workaround (from the first linked thread):
add address=1.2.3.246/32 network=1.2.3.247 interface=ether1
i.e. set CPE IP as its address with 32-bit netmask and set AR’s IP address as network address.
I certainly hope the right guy will come by and correct my mistakes …
Thats got it. Nice one. Apprecaite it and seams obvious when you look at the solution.
Thanks again
Tim
