I know that there is already a lot of content about how to properly configure wifi APs in this forum, but still, I am experiencing multiple issues in my setup and am still struggling to configure them.
I have 1000 square meter space with 4 cAP ax (one in each corner).
I don’t use CAPsMAN as I have experiences issues in the past with broadcasting, and it makes my network more complicated (I have a lot of different networking hardware between the router and the APs and CAPsMAN makes it seem like the APs are plugged directly on the router.).
Finally, my APs have two SSIDs: a guest and a main, on two different VLANs.
My problems are the following:
- A lot of devices connect to the 2ghz network, even though there is the 5ghz network with the same SSID next to it.
- Even though I am next to an AP, my computer tends to stay connected to an AP very far away.
- Apple users are experiencing connectivity issues (cannot connect to wifi).
- It is takes some time connecting to the wifi
What I have tried so far:
- Reducing the TX-Power of the 2ghz antenna
- Enabling FT & FT Over DS
- Switching from 20Mhz to 20/40MHz Ce on the 5Ghz antenna
- Disabling WPA3-PSK (leaving only WPA2-PSK)
Here is an export
add name=bridge1 port-cost-mode=short vlan-filtering=yes
/interface vlan
add interface=bridge1 name=vlan30 vlan-id=30
add interface=bridge1 name=vlan40 vlan-id=40
add interface=bridge1 name=vlan99 vlan-id=99
/interface wifi channel
add band=2ghz-ax disabled=no frequency=2412 name=2ghz width=20mhz
add band=5ghz-ax disabled=no name=5ghz width=20/40mhz-Ce
/interface wifi security
add authentication-types=wpa2-psk disabled=no name=Main
add authentication-types=wpa2-psk disabled=no name=Guest
/interface wifi configuration
add country=France disabled=no mode=ap name=Guest security=Guest ssid=Guest
add country=France disabled=no mode=ap name=Main security=Main ssid=Wifi-Prive
/interface wifi
set [ find default-name=wifi2 ] channel=2ghz configuration=Main configuration.mode=ap .tx-power=5 disabled=no name="Main 2ghz" security=Main
set [ find default-name=wifi1 ] channel=5ghz channel.skip-dfs-channels=all configuration=Main configuration.mode=ap disabled=no name="Main 5ghz" security=Main
add configuration=Guest configuration.mode=ap disabled=no mac-address=7A:9A:18:C9:6C:72 master-interface="Main 2ghz" name="Guest 2ghz" security=Guest
add configuration=Guest configuration.mode=ap disabled=no mac-address=7A:9A:18:C9:6C:71 master-interface="Main 5ghz" name="Guest 5ghz" security=Guest
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether1 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface="Main 5ghz" internal-path-cost=10 path-cost=10 pvid=30
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface="Main 2ghz" internal-path-cost=10 path-cost=10 pvid=30
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface="Guest 5ghz" internal-path-cost=10 path-cost=10 pvid=40
add bridge=bridge1 interface="Guest 2ghz" pvid=40
/interface bridge vlan
add bridge=bridge1 tagged=ether1 vlan-ids=30
add bridge=bridge1 tagged=ether1 vlan-ids=40
add bridge=bridge1 tagged=bridge1,ether1 vlan-ids=99
/ip dhcp-client
add interface=vlan99
/system identity
set name=AP-Prod
Thank you for your help,
Arnaud
