There must be away to modify the columns within User Manager when viewing/adding users.
Or, at a minimum, how can I dump a list of all the users with passwords in a clean CSV? Exporting from the terminal and then trying to delimit within Excel does not work well.
As you can see in the attachment below all it takes is first selecting ‘advanced search’ from the tab list on the left and either changing the field with ‘username’ to ‘first name’ or ‘last name’. Otherwise, you can add extra fields by clicking the plus sign.
Again, if you select ‘settings’ on the left, it allows you specify which columns are visible and which ones are not. You can modify this for routers, sessions, customers etc as well.
If you want to dump a list of users and their passwords, from terminal:
/tool userman user export file=umuser
Then check in your router file list for umuser.rsc, download to your computer and open with notepad or other editor of your choice.
What you’ve shown me is exactly what I want. I appreciate your time. But, I do not know where you are grabbing that screen shot from. My User Manager 4.5 looks completely different.
I access User Manager from http://router ip/userman/
