um 6.37.1 timezone issue
hello,
when i add validity to profiles that starts at first logon i got a different timestamp in startime field it is delayed by 8 hours. my timezone is +8:00 and set correctly in system clock and activated sntp client. um router timezone is parent while customer is +8:00, i did change router and customer to +8:00 to no avail.
thanks
Same problem, Can someone help us?
back up file naming is also affected, dont know what else to do as i’ve tried every possible cause
Thank you for reporting, seems like the backup save time needs a fix. But I did not saw any problem with the session from time. Can you give more examples ?
Sessions/logs/reports show correct from time, if the customer time zone is set (6.37.1/6.38rcX)
hi paul this is on +8:00 timezone, start time it is clearly delayed by 8 hours from the real start time
even after upgrading to 6.37.2 start time is still off by 8 hours
6.37.5 timezone bug +1
