UM, DHCP, PPPoE
Greetings,
How to configure UM to authenticate PPPoE users and give away IP address, Gateways and DNS?
Added pppoe-in interface, pppoe server in mt. Then added a dhcp server to use radius. in UM added a user and successfully connected. But getting no IP. MT log says “dhcp error radius authentication failed for xx:xx:xx:xx:xx:xx. xx:xx:xx:xx:xx:xx user not found”. what is wrong?
After reading enough it seems dhcp server cannot be used with um without creating users login name by their mac. Instead an ip pool can be used in limitations. But ip pool does not have default gateway or dns. So the pppoe users will not get any gateways or dns dynamically?
Anyone?
No one knows if it is possible? I want to know this 'cause my pppoe users r not getting any internet even after giving DNS manually.
