UM on a rb450
I have just started adding customers to my User Manager which is running on a 450 for the moment.
The first couple of customers went on to it ok, but now it does not seem to accept any more than 5 clients at a time, the rest of them are authorised ok then are terminated immediately.
If I create the customers log in detail user PPP/secrets they connect fine.
Is there a restriction to running user manager on a 450?
No..
There IS a usermanager limit based on Lic version..
You can add as many users as you wish, but it will only Auth X number at a time…
Check the MikroTik site for counts..
I THINK it is 10 for a lvl 4, and 50 for a Lvl 5, amd unlimited for a Lvl 6…
But check the site to verify..
