UM PPTP/L2TP and Static Routes
I am trying to setup UM to be used for authenticating some PPTP/L2TP VPNs on 4 MikroTik routers.
Using the regular PPP Secrets I can specify for each user what static routes will be inserted on his/her routing table once connected to the VPN server.
Specifically I need the VPN to be used to route only 10.0.0.0/8 through it. The rest of each user’s traffic should go through his/her internet gateway.
Eg:
The problem is that I cannot find on UM any relative option to define what static routes will be inserted to the user’s PC once connected to the VPN server.
Has anyone tried this before?
Any ideas on how to implement this?
Thanks!
