UM Scripting Variable Names?
is there a place to get a list of all variable names in UM?
/tool user-manager user>print
you can only find few here but how to get to certain data of users for example: /tool user-manager user get (actual profile) or (pool)?
how to know one user is set to what profile and change it by a script to another profile?
thank you
I’m not very familiar with UM, but wouldn’t the tab and question mark keys auto complete things and show all the available options?
Tab key and ? mark is almost puts the same output. I am more looking for variables related to a user’s profile.
If I can search for a user and find it’s profile, I can then change the profile to something else on the fly.
I found out I can let one router connect to another using scripts and ssh. This is a good news for me since
I can look at a user’s daily volume from UM and have UM enter other routers to change its dynamic queue without
making the user logout at all.
so a list of variable names of UM is needed to accomplish this.
thanks,
Have a look at the wiki
Thank you for this really good reply. I will defiantly benefit from it since i can see variables for profiles.
Thank you
