UM ver3 on ros v6
Hi is it possible to run um ver3 on ros v6
NO!
UM and ROS versions most match.
… But you should be able to upgrade your RouterOS v3 to RouterOS v6 with little to no problems, including upgrading user manager. Keep a backup of course, just in case.
Hi Ok I thought this was the case. I need Ver3 of usermanager for the way we work.
