unable to access isp gateway
I am trying to set up a ccr-1016-12s-1s+ with my dedicated fiber connection. It’s a simple static ip configuration. I can connect to the internet using cheap routers or simply using my pc but the ccr will not work no matter what I try. I must be missing some important step. From the router’s terminal I cannot ping the gateway or google dns and gateway is unreachable. My ISP gives me a ethernet connection from a ciena box. Also, I am unable to connect this router downstream of one of the cheap routers using a dhcp client on the wan interface, the status never changes from “searching”. Thanks for any ideas you might have.
