I’m fairly new to Mikrotik/setting up my own router/switch CSR310-8g+2s+in.
I have an IOT VLAN (172.16.10.x) but have had issues getting devices on the main network (172.16.0.x) to acces them. When I disable all drop firewall rules, I still can’t access VLAN10 devices so I’m not sure where the issue is. What I’m hoping to accomplish
- Any device on main network can access IOT VLAN devices
- IOT VLAN devices can communicate with Home Assistant on the main network (If this is not possible, please let me know. I need home assistant to access devices on both main and VLAN networks)
Config
# 2025-06-16 07:01:22 by RouterOS 7.13.5
# software id = **ELIDED**
# model = CRS310-8G+2S+
# serial number = **ELIDED**
add name=bridge port-cost-mode=short vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1_Internet
set [ find default-name=ether4 ] name=ether4_Desktop
set [ find default-name=ether7 ] name=ether7_TPLink
set [ find default-name=sfp-sfpplus1 ] name=sfp-sfpplus1_server
/interface wireguard
add disabled=yes listen-port=13231 mtu=1420 name=wireguard1
/interface vlan
add interface=bridge name=VLAN10-IoT vlan-id=10
add interface=bridge name=VLAN20 vlan-id=20
/interface ethernet switch
set 0 l3-hw-offloading=yes
set 0 l3-hw-offloading=no
add include=all name=LAN
add include=all name=WAN
/ip hotspot profile
add name=dhcp_pool0 ranges=172.16.0.20-172.16.0.254
add name=dhcp_pool1 ranges=172.16.10.2-172.16.10.254
add name=dhcp_pool2 ranges=172.16.200.1-172.16.200.254
add address-pool=dhcp_pool1 interface=VLAN10-IoT name=dhcp2
add address-pool=dhcp_pool2 interface=VLAN20 lease-time=8h name=dhcp3
/port
set 0 name=serial0
/user group
add name=hassio policy="read,test,api,!local,!telnet,!ssh,!ftp,!reboot,!write,!policy,!winbox,!password\
,!web,!sniff,!sensitive,!romon,!rest-api"
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" name=zt1 port=9993
/zerotier interface
add instance=zt1 name=zerotier1 network=23…**ELIDED**
add bridge=bridge hw=no interface=ether4_Desktop internal-path-cost=10 path-cost=10
add bridge=bridge hw=no interface=ether8 internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge hw=no interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge hw=no interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge hw=no interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge comment="TPLink Trunk Port" hw=no interface=ether7_TPLink internal-path-cost=10 \
path-cost=10
add bridge=bridge interface=sfp-sfpplus1_server
add bridge=bridge hw=no interface=sfp-sfpplus2
/interface bridge vlan
add bridge=bridge tagged=bridge,ether3,sfp-sfpplus1_server,ether7_TPLink vlan-ids=10
add bridge=bridge tagged=ether3,bridge vlan-ids=20
add interface=bridge list=LAN
add interface=ether1_Internet list=WAN
add interface=wireguard1 list=LAN
/interface wireguard peers
add allowed-address=172.16.20.2/32 disabled=yes interface=wireguard1 public-key="**ELIDED**"
add allowed-address=172.16.20.3/32 disabled=yes interface=wireguard1 public-key="**ELIDED**"
add address=172.16.0.1/24 interface=bridge network=172.16.0.0
add address=172.16.10.1/24 interface=VLAN10-IoT network=172.16.10.0
add address=172.16.200.0/24 interface=VLAN20 network=172.16.200.0
add address=172.16.20.1/24 comment="Wireguard IP range" interface=wireguard1 network=172.16.20.0
/ip dhcp-client
add interface=ether1_Internet use-peer-dns=no
add address-pool=dhcp_pool0 interface=bridge name=dhcp1 parent-queue=*FFFFFFFF
add address=172.16.0.0/24 dns-server=172.16.0.1 gateway=172.16.0.1
add address=172.16.10.0/24 dns-server=172.16.10.1 gateway=172.16.10.1
add address=172.16.200.0/24 gateway=172.16.200.0
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=172.16.0.30 comment="homeassistant redirect" name=homeassistant.local
/ip firewall address-list
add address=172.16.0.0/24 list=LOCAL_IPs
add address=172.16.10.0/24 list=IoT_IPs
add address=172.16.10.245 list=Google_Home_IPs
add address=172.16.10.251 list=Google_Home_IPs
add address=172.16.200.0/24 list=IoT_IPs
add address=172.16.0.248 list=PS5
add list=crowdsec
add address=172.16.0.38 list=homeassistant
add address=172.16.10.187 list=homeassistant
add action=accept chain=forward in-interface=zerotier1
add action=accept chain=input in-interface=zerotier1
add action=fasttrack-connection chain=forward connection-state=established,related hw-offload=no
add action=accept chain=forward connection-state=established,related
add action=accept chain=forward comment="Allow local traffic to VLAN" dst-address-list=IoT_IPs \
src-address-list=LOCAL_IPs
add action=accept chain=forward comment="test plex forward" connection-nat-state=dstnat
add action=accept chain=forward dst-address=172.16.0.1 dst-port=53 protocol=udp src-address-list=\
IoT_IPs
add action=accept chain=input comment="HOAS TPLink port" dst-port=9999 in-interface=ether1_Internet \
protocol=tcp
add action=accept chain=forward comment="Allow VLAN trafic to HOAS" dst-address-list=homeassistant \
src-address-list=IoT_IPs
add action=accept chain=forward comment="Allow Home Assistant to access main LAN" dst-address-list=\
LOCAL_IPs src-address=172.16.10.187
add action=drop chain=forward comment="Drop IoT outbound traffic" connection-nat-state="" \
connection-state=new dst-address-list=LOCAL_IPs src-address-list=IoT_IPs
add action=drop chain=forward connection-nat-state=!dstnat connection-state=new in-interface=\
ether1_Internet
add action=masquerade chain=srcnat out-interface=ether1_Internet
add action=masquerade chain=srcnat out-interface=VLAN10-IoT
add action=masquerade chain=srcnat comment="Allow local access on Wireguard" disabled=yes \
out-interface=bridge src-address=172.16.20.0/24
add action=dst-nat chain=dstnat comment=Plex dst-port=32400 in-interface-list=WAN protocol=tcp \
to-addresses=172.16.0.22
add action=dst-nat chain=dstnat comment=tplink dst-port=29810-29816 in-interface-list=WAN protocol=tcp \
add action=accept chain=dstnat comment="PS5 Remote Play" dst-address-list=PS5 dst-port=\
9295-9308,8572,987 in-interface=ether1_Internet protocol=udp
add action=accept chain=dstnat comment="PS5 Remote Play" dst-address-list=PS5 dst-port=9295-9308,8572 \
in-interface=ether1_Internet protocol=tcp
add action=accept chain=dstnat comment="Sunshine Ports" dst-address-list=sunshine_servers dst-port=\
47989,47984,48010 in-interface=ether1_Internet protocol=tcp
48010,47998,47999,47800 in-interface=ether1_Internet protocol=udp
add action=accept chain=dstnat comment=Zerotier dst-port=9993,39758,27284,36875,21291 in-interface=\
add action=accept chain=srcnat comment=Zerotier dst-port=9993,39758,27284,36875,21291 out-interface=\
add action=accept chain=dstnat comment="Tailscale Wireguard" dst-address-list=sunshine_servers \
dst-port=41641 in-interface=ether1_Internet protocol=udp
add action=accept chain=srcnat comment="Tailscale HTTPS" dst-port=443 out-interface=ether1_Internet \
protocol=udp src-address-list=sunshine_servers
protocol=tcp src-address-list=sunshine_servers
/ip upnp
set enabled=yes
/system clock
set time-zone-name=**ELIDED**
/system note
set show-at-login=no
/system routerboard settings
set boot-os=router-os
/tool sniffer
set streaming-enabled=yes streaming-server=172.16.0.56
