Hi all,
I’m having somewhat of a newbie issue with my RB450(not G) running RouterOS 3.30.
What I’ve got is a WAN on ether1, with VLAN with id 235, and a local subnet on ether2, with ether3-4 slaved to it. DHCP server is configured on LAN.
So far, machines on the LAN can ping/connect to each other and the mikrotik. But can’t ping anything on WAN, or vice versa.
No wireless, this is a really simple config, which is making it even more embarrassing.
Config dumps incoming. What have I done wrong? Because I know I’ve done something wrong…
interface export
# jan/02/1970 00:03:19 by RouterOS 3.30
# software id = RKE1-E2IU
set 0 arp=enabled auto-negotiation=yes comment="" disabled=no full-duplex=yes l2mtu=1526 mac-address=00:0C:42:52:19:70 mtu=1500 name=ether1 speed=1Gbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:52:19:71 master-port=none mtu=1500 name=ether2 speed=1Gbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:52:19:72 master-port=ether2 mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:52:19:73 master-port=ether2 mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:52:19:74 master-port=ether2 mtu=1500 name=ether5 speed=100Mbps
/interface vlan
add arp=enabled comment="" disabled=no interface=ether1 l2mtu=1522 mtu=1500 name=inet use-service-tag=no vlan-id=235
set default authentication-types="" eap-methods=passthrough group-ciphers="" group-key-update=5m interim-update=0s mode=none name=default radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-key-0="" static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=none static-sta-private-key="" static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates \
unicast-ciphers="" wpa-pre-shared-key="" wpa2-pre-shared-key=""
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
/interface ethernet mirror
set mirror-port=none source-port=none
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 mac-address=FE:29:19:EE:39:DF max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
ip export hide-sensitive
# jan/02/1970 00:12:29 by RouterOS 3.30
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m name=default pfs-group=modp1024
add name=lan-pool ranges=192.168.23.2-192.168.23.100
add address-pool=lan-pool authoritative=after-2sec-delay bootp-support=static disabled=no interface=ether2 lease-time=3d name=lan-dhcp
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=116.90.134.242/29 broadcast=116.90.134.247 comment="default configuration" disabled=no interface=inet network=116.90.134.240
add address=192.168.23.1/24 broadcast=192.168.23.255 comment="" disabled=no interface=ether2 network=192.168.23.1
/ip dhcp-client
add add-default-route=yes comment="" default-route-distance=1 disabled=no interface=ether1 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.23.0/24 comment="" dns-server=192.168.23.1 gateway=192.168.23.1
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=4096 primary-dns=202.6.116.124 secondary-dns=0.0.0.0
/ip dns static
add address=192.168.23.1 disabled=no name=router ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="" disabled=no protocol=icmp
add action=accept chain=input comment="" connection-state=established disabled=no
add action=accept chain=input comment="" connection-state=related disabled=no
add action=accept chain=forward comment="" disabled=no out-interface=inet
add action=accept chain=output comment="" disabled=no protocol=icmp
add action=accept chain=input comment="" disabled=no dst-port=9322 protocol=tcp
add action=drop chain=input comment="" disabled=no
add action=masquerade chain=srcnat comment="" disabled=no out-interface=ether1
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1 discover=no
set ether2 discover=yes
set ether3 discover=yes
set ether4 discover=yes
set ether5 discover=yes
set inet discover=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no enabled=no max-cache-size=none max-client-connections=600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=119.60.134.246 scope=30 target-scope=10
/ip service
set telnet address=0.0.0.0/0 disabled=yes port=23
set ftp address=0.0.0.0/0 disabled=yes port=21
set www address=0.0.0.0/0 disabled=yes port=80
set ssh address=0.0.0.0/0 disabled=no port=9322
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=192.168.23.0/24 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
