Unable to access Winbox from outside network
Hi to all Mtk lovers..
I have one RB911 with LAN IP say xxx.172.140.50, GW xxx.172.140.49 and WAN IP: 5.5.5.1/30
with NAT rule dstnat, dst address xxx.172.140.50 (Static), 6tcp, dtsport- 8292, action dst-nat, dst-address-5.5.5.2, posrt-8291
and srcnat with action masquerade.
this 911 is connected with 433AH as AP, having IP address 172.16.0.1/24, GW 5.5.5.1 and google DNS, in WLAN1 which has an Omnitik connected.
and on WLAN2 the PTP with 911 is ON.
in Addresses i have assigned 5.5.5.2/30 and xxx.172.140.58/29 (Static).
the IP xxx.172.140.50 is fully accessible from other networks, now when I use xxx.172.140.58 from other network it is not accessible.
i dont know where i am wrong as i am newb.
One More thing.. I m using Hotspot for my internal network 172.16.0.0/24, but now i want to bypass one IP 172.16.0.56, through firewall with datalimit 2 Mbps. What should be the script for NAT rule.
Please help me out. I will be obliged.
You’re being a bit chaotic.
Could you draw some schematic of the network?
