unable to activate smb by winbox, but ok with web
could you please confirm if it’s a bug with version 6.4 ? same bug with rb2011uas-2hnd and rb2011uas.
I tried to activate by winbox the smb share file but I’m not able, by the web access is ok and
by the terminal windows is ok too.
The enable square is gray (not available) see the photo
Someone can confirm please ?
Thank you for your answer
I found it is OK in Router OS 6.4, I just upgrade my RB951G-2HnD, no problem at all. did you try reboot your router after upgrade your OS?
Hi nawshad,
I have the same bug with ver 6.4, enable is gray with winbox but ok via the http web site, I have in stock 4 mikrotik with ver 6.4 they have the same problem, I checked with my RB951G-2HnD too, I reboot, do reset factory always no enable check available with winbox !
Hummm it’s weird, a glitch with winbox ?
maxspeed
there is a bug that’s for sure. what i do 2 times close and open IP ==> SMB then it active automatically :slight_smile: look the image i’ve attached.
nothing I can do with winbox, I tried my 4 devices with ver 6.4 same problem, if go to IP-> smb the enable is gray, by Http or terminal working fine …
I can do the setup by 2 last ways, but it will be good if mikrotik can confirm if that is a problem ???
The weird thing is with winbox I can’t change anything after the setup, but the share and user I can do everything ! (not → enable, domain, comment, allow, interfaces)
Thank you for your tests !
maxspeed
