Unable to connect SIP server behind Mikrotik?
Hi Every1,
Has anyone been successful setting up SIP server to work behind Mikrotik Router OS?
Recently we installed NEC SV8100 IP-PBX at one of our customer where routing and firewall is done with Mikrotik. When user is in the same network as NEC everything work fine but when same user tries to connect from outside network (Home/Remote) never succeed to register.
Have been trying every possible technique found while googling but have succeeded yet.
If anyone can help!!!
Have you got any SIP traces?
Like What Marrold?
Like actually debugging the SIP connection to see if it is not getting the ACK, if the NEC PABX is actually receiving the initial request and sending the ACK, need to find out which part of the registration handshake fails to correctly identify what needs to be looked at.
Works on our system, using IPLA. If using IPLB, then only 1 IP is used, not 8, so adjust the RTP accordingly.
SV8100 IP 192.168.0.186
IPLA 1 IP 192.168.0.187
IPLA 2 IP 192.168.0.188
IPLA 3 IP 192.168.0.189
IPLA 4 IP 192.168.0.190
IPLA 5 IP 192.168.0.191
IPLA 6 IP 192.168.0.192
IPLA 7 IP 192.168.0.193
IPLA 8 IP 192.168.0.194
On the router connected to the handset network (external), forward port UDP/5060 to the IP address of the handset. Also forward port UDP/3462 to the IP address of the handset.
Hope this helps.
add action=netmap chain=dstnat comment="SIP Control" disabled=no dst-port=\
    5080-5086 in-interface=pppoe-out1 protocol=udp to-addresses=192.168.0.186 \
    to-ports=5080-5086
    3462-3467 in-interface=pppoe-out1 protocol=udp to-addresses=192.168.0.187 \
    to-ports=3462-3467
add action=netmap chain=dstnat comment=RTP disabled=no dst-port=\
    10020-10051 in-interface=pppoe-out1 protocol=udp to-addresses=\
    192.168.0.187 to-ports=10020-10051
    10052-10083 in-interface=pppoe-out1 protocol=udp to-addresses=\
    192.168.0.188 to-ports=10052-10083
    10084-10115 in-interface=pppoe-out1 protocol=udp to-addresses=\
    192.168.0.189 to-ports=10084-10115
    10116-10147 in-interface=pppoe-out1 protocol=udp to-addresses=\
    192.168.0.190 to-ports=10116-10147
    10148-10179 in-interface=pppoe-out1 protocol=udp to-addresses=\
    192.168.0.191 to-ports=10148-10179
    10180-10211 in-interface=pppoe-out1 protocol=udp to-addresses=\
    192.168.0.192 to-ports=10180-10211
    10212-10243 in-interface=pppoe-out1 protocol=udp to-addresses=\
    192.168.0.193 to-ports=10212-10243
    10244-10275 in-interface=pppoe-out1 protocol=udp to-addresses=\
    192.168.0.194 to-ports=10244-10275
