I am unable to connect to the hAP lite after a manual update.
Unable to resolve IP address via DHCP or connect via Winbox when static IP applied.
Unable to connect via MAC address either.
Resetting configuration to default via reset switch not working either.
try download latest winbox from mikrotik website and use it if you are sure the router boot fully,
otherwise make sure the router is reset before lauching the winbox
Goodluck
