Unable to connect to Microsoft Teams when using RB4011IGS+5HACQ2HND-IN
I’ve just started using a router (MikroTik RB4011IGS+5HACQ2HND-IN) to connect to Internet. I’m unable to connect to Microsoft Teams when using this router.
At same time connecting through two other old routers of mine (one driven by OpenWrt, the other by its own firmware - without special tweaking) work fine with Microsoft Teams.
The issue is reproducible from different clients (Windows 10, Ubuntu Linux, Android smartphone) so I suspected it could be an issue related to my router.
I guess there is some caveat with firewall settings. I’m using NAT, firewall settings are left default. I tried disabling drop filter rules but that didn’t help.
Here are my ip filter settings:
/ip firewall filter> export
# may/11/2020 16:23:19 by RouterOS 6.46.6
## model = RB4011iGS+5HacQ2HnD
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
    in-interface-list=WAN
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
Any assistance is welcome - either about configuring the router or getting logs and diagnostics to better understand it.
What are your DNS settings ? Your clients use some direct ISP DNS servers or is the Mikrotik intermediate ?
All other web-access works fine I guess ?
You said you started using it recently? Are all settings out of the box or did you customize anything. There should be 0 issues with Teams running out of the box.
Concur, i use MS teams and had nothing to do on the router.
Tells me something is screwy withe your MS Teams load on your pC, or something is configured incorrectly on the router.
Thanks for sharing your feedback! Good to know that MS Teams works elsewhere - could you confirm if RouterOS version is the same like mine?
I haven’t customized the firewall, I just did some minor WiFi adjustmenets. The issue is reproducible on several devices so I guess it’s not something specific to my PC/phone. All other network works fine so far. Including communication software like Skype, Skype for Business, Zoom.
I am using DHCP and automatic DNS (MikroTik intermediary - DHCP and DNS are enabled in MikroTik).
I consider resetting my router settings to default just in case…
# may/11/2020 15:09:48 by RouterOS 6.46.6
# software id = T6YZ-SZKV
# model = 2011UiAS
Trying the long-term/testing router versions didn’t help.
I traced teams process from old and new (MikroTik) routers and I have a feeling that there might be something with IPV6 or/and UDP and ICMP. Disabling IPV6 on the old router leads to similar issue (it works fine with IPV6 enabled).
An excerpt from strace of teams when running through the old (working fine) router:
[pid 40310] socket(AF_INET, SOCK_DGRAM|SOCK_CLOEXEC, IPPROTO_IP) = 100
[pid 40310] connect(100, {sa_family=AF_INET, sin_port=htons(0), sin_addr=inet_addr("52.113.194.132")}, 16) = 0
[pid 40266] connect(97, {sa_family=AF_INET6, sin6_port=htons(53), sin6_flowinfo=htonl(0), inet_pton(AF_INET6, "2001:4860:4860::8888", &sin6_addr), sin6_scope_id=0}, 28) = 0
And from the MikroTik one:
  • It tries to connect via TCP instead of UDP (as was the case with my old router)
[pid 40063] socket(AF_INET, SOCK_STREAM, IPPROTO_TCP) = 98
[pid 40063] setsockopt(98, SOL_TCP, TCP_NODELAY, [1], 4) = 0
[pid 40063] setsockopt(98, SOL_SOCKET, SO_KEEPALIVE, [1], 4) = 0
[pid 40063] setsockopt(98, SOL_TCP, TCP_KEEPIDLE, [45], 4) = 0
[pid 40063] setsockopt(98, SOL_TCP, TCP_KEEPINTVL, [45], 4) = 0
[pid 40063] connect(98, {sa_family=AF_INET, sin_port=htons(443), sin_addr=inet_addr("52.113.194.132")}, 16) = -1 EINPROGRESS (Operation now in progress)
[pid 40063] getsockopt(98, SOL_SOCKET, SO_ERROR, [0], [4]) = 0
[pid 40060] recvmsg(27, {msg_namelen=0}, 0) = -1 EAGAIN (Resource temporarily unavailable)
  • A connection to an address failed which worked OK with the old router
[pid 40063] socket(AF_INET6, SOCK_DGRAM, IPPROTO_IP) = 98
[pid 40063] connect(98, {sa_family=AF_INET6, sin6_port=htons(53), sin6_flowinfo=htonl(0), inet_pton(AF_INET6, "2001:4860:4860::8888", &sin6_addr), sin6_scope_id=0}, 28) = -1 ENETUNREACH (Network is unreachable)
[pid 40138] sendto(27, "\310\0\0\0\20\0\1\0\0\0\0\0\0\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 200, MSG_NOSIGNAL, NULL, 0) = 200
And then I tried much simpler test which works fine on my old routers and fails on the MikroTik one:
$ ping6 2001:4860:4860::8888
ping6: connect: Network is unreachable
I managed to resolve my IPv6 issue (see http://forum.mikrotik.com/t/ipv6-setup/139467/1) and after Microsft Teams is working fine for me :slight_smile:
