Unable to connect to rb500
The issue started with the red led lighting up on startup, I couldn’t connect to the unit until I held in the reset button and the red LED went off after 3 sec. Then I could connect to the unit using winbox by specifing the IP I had assigned to the ethernet port. In and attempt to fix that porblem I reset the board to the factory defaults and now I can’t connect to it with anything. It seems to be booting up i.e. the red light stills goes out after 3 secs when I hold in the reset button, and I get another beep after 15 sec but I can detect it with winbox, neighbour viewer netinstall, or a hyperterminal session. Help Please.
E
Try to connect null modem cable and check the output from the router.
http://wiki.mikrotik.com/wiki/First_time_startup
